RS4 B7 Interior Light Pack
Fellas
did the B7 ever come with a interior light pack option? (Same as A6)
Dale
Dale
07 RS4 Avant (Cherry)
Re: RS4 B7 Interior Light Pack
Yes - they all had it as standard
yes and upgrade to led's aswell. just done it yesterday! so much nicer!!
r
r
B7 RS4 avant misano red
Black optics rpsxr style
Hmmm... I cant remember seeing it on in mine. Is there a way of turning it off?
- PetrolDave
Not that I've ever heard of and certainly not using VCDS - apart from a blown fuse.d9lek42 wrote:Hmmm... I cant remember seeing it on in mine. Is there a way of turning it off?
might be blown fuse. found out i had one blown. fuse no2, which is footwell lights, but also the ashtray is on it...
do they light up just under the door trims as well like the A6.... i should have looked really but only got it 4 days before i came back to work so was too busy having a playrpsxr wrote:might be blown fuse. found out i had one blown. fuse no2, which is footwell lights, but also the ashtray is on it...
Yes, the lights are under the doors and front + rear footwells (and door handles I think...)
ok cool... i'll have a butchers when i get back from the land of sand and camel <beep>
there's a white one in the bottom of every door (puddle light) plus a red one on the side of every door.
there's one i n each footwell and dependant if you have buckets, also in the back.
r
r
I bought an array of LED bulbs for the interior lights.
The festoon type all work fine, but the bayonets (BA9S) used in the switchable map reading lights don't. They work when all interiors lights are on, but if you use them independently (i.e. just switch on map lights) they don't light. I'm guessing this is because when using the map light switches the polarity is reversed?
Is there any way round this by adding additional resistors, or am I just talking bollox (quite likely).
Pretty sure mine work on their own, I'll check tonight. I think if you turn on just the rears they flashed at first but that stopped.jobbys wrote:I bought an array of LED bulbs for the interior lights.
The door handles have the red LEDs dont they, as well as in the front centre roof bit? Was that part of the light pack or a seperate option or standard? Couldnt really see them when I lived in london as it was alwyas too bright but more obvious now i'm in the stick with unlit roads.
think they're standard. they've been on all my audis in the past as well. (a6 a4 a3)
- PetrolDave
Resistors won't swap the polarity so won't solve the problem if it's caused by a polarity swap.jobbys wrote:Is there any way round this by adding additional resistors, or am I just talking bollox (quite likely).
If you are talking about the red LEDs they were definitely not standard on all A4s, maybe standard on the RS4 though and maybe part of the lighting pack. There was a big thread somewhere about retro fitting them so can't be standard on all Audis.rpsxr wrote:think they're standard. they've been on all my audis in the past as well. (a6 a4 a3)
Users browsing this forum: Majestic-12 [Bot] and 383 guests
