RS4 B7 Interior Light Pack
d9lek42
Post by d9lek42 » Sun Nov 25, 2012 2:50 pm
Fellas
did the B7 ever come with a interior light pack option? (Same as A6)
Dale
07 RS4 Avant (Cherry)
pDkALO
Re: RS4 B7 Interior Light Pack
Post by pDkALO » Sun Nov 25, 2012 3:02 pm
Yes - they all had it as standard
Current: Macan Turbo, Boxster 987 S
Gone: RS6 C6 Avant, RS4 B7 Avant, Tamora Speed Six
rpsxr
Post by rpsxr » Sun Nov 25, 2012 3:07 pm
yes and upgrade to led's aswell. just done it yesterday! so much nicer!!
r
B7 RS4 avant misano red
Black optics rpsxr style
:redrs4:
d9lek42
Post by d9lek42 » Sun Nov 25, 2012 3:11 pm
Hmmm... I cant remember seeing it on in mine. Is there a way of turning it off?
PetrolDave
Post by PetrolDave » Sun Nov 25, 2012 3:37 pm
d9lek42 wrote:Hmmm... I cant remember seeing it on in mine. Is there a way of turning it off?
Not that I've ever heard of and certainly not using VCDS - apart from a blown fuse.
rpsxr
Post by rpsxr » Sun Nov 25, 2012 3:57 pm
might be blown fuse. found out i had one blown. fuse no2, which is footwell lights, but also the ashtray is on it...
:redrs4:
d9lek42
Post by d9lek42 » Sun Nov 25, 2012 4:05 pm
rpsxr wrote:might be blown fuse. found out i had one blown. fuse no2, which is footwell lights, but also the ashtray is on it...
do they light up just under the door trims as well like the A6.... i should have looked really but only got it 4 days before i came back to work so was too busy having a play :kissmyrings:
pDkALO
Post by pDkALO » Sun Nov 25, 2012 4:11 pm
Yes, the lights are under the doors and front + rear footwells (and door handles I think...)
d9lek42
Post by d9lek42 » Sun Nov 25, 2012 4:13 pm
ok cool... i'll have a butchers when i get back from the land of sand and camel <beep> :)
rpsxr
Post by rpsxr » Sun Nov 25, 2012 5:32 pm
there's a white one in the bottom of every door (puddle light) plus a red one on the side of every door.
there's one i n each footwell and dependant if you have buckets, also in the back.
r
:redrs4:
jobbys
Post by jobbys » Mon Nov 26, 2012 9:54 am
I bought an array of LED bulbs for the interior lights.
The festoon type all work fine, but the bayonets (BA9S) used in the switchable map reading lights don't. They work when all interiors lights are on, but if you use them independently (i.e. just switch on map lights) they don't light. I'm guessing this is because when using the map light switches the polarity is reversed?
Is there any way round this by adding additional resistors, or am I just talking bollox (quite likely).
Post by MikeFish » Mon Nov 26, 2012 3:32 pm
jobbys wrote:I bought an array of LED bulbs for the interior lights.
Pretty sure mine work on their own, I'll check tonight. I think if you turn on just the rears they flashed at first but that stopped.
The door handles have the red LEDs dont they, as well as in the front centre roof bit? Was that part of the light pack or a seperate option or standard? Couldnt really see them when I lived in london as it was alwyas too bright but more obvious now i'm in the stick with unlit roads.
rpsxr
Post by rpsxr » Mon Nov 26, 2012 5:52 pm
think they're standard. they've been on all my audis in the past as well. (a6 a4 a3)
:redrs4:
PetrolDave
Post by PetrolDave » Mon Nov 26, 2012 6:13 pm
jobbys wrote:Is there any way round this by adding additional resistors, or am I just talking bollox (quite likely).
Resistors won't swap the polarity so won't solve the problem if it's caused by a polarity swap.
Post by MikeFish » Mon Nov 26, 2012 6:28 pm
rpsxr wrote:think they're standard. they've been on all my audis in the past as well. (a6 a4 a3)
If you are talking about the red LEDs they were definitely not standard on all A4s, maybe standard on the RS4 though and maybe part of the lighting pack. There was a big thread somewhere about retro fitting them so can't be standard on all Audis.
Users browsing this forum: No registered users and 265 guests
