B7 RS4 Rolling Road Day 18th April 2009 (Free of Charge)
ArthurPE
Post by ArthurPE » Sat May 23, 2009 6:39 pm
Dom81 wrote:
ArthurPE wrote: all 4 graphs make ~ the same RAW power at 40 mph (145 or so, the lowest being dubs at 140)), the cf's are different for the cars at this speed
Oli 0.22
Dom 0.25
P_G 0.30
dubber 0.29
You lost me at this point - can you put into (very) simple words please!
the wheel HP measured (actually it measures torque and calculates HP) by the dyno was the same (within 2HP from the average) for all 4 cars...but they each had a different correction factor for some reason...
so using the average wheel HP of ~145...if you use P_G's cf that equals ~188 at the crank...if you use Oli's that equals 177, >6% difference...for the same measured power....
RI_RS4
Post by RI_RS4 » Sat May 23, 2009 7:06 pm
Arthur,
comparisons at 40 MPH on a 3rd Gear pull are useless. RPM and airflow is low at this point in the curve. The throttle body is only open 50% at this point. Where you will see differences is in the "boost" that occurs between 4500 and 5500 rpm, when the short intake runner is switched in and (in some cases) the intake power flap is opened. In dubs case I believe he'll find a massive timing pull, either an intake restriction or obstructed flow at the valves. Something was not right with this engine when it when the throttle body opened.
ArthurPE
Post by ArthurPE » Sat May 23, 2009 7:51 pm
RI_RS4 wrote:Arthur,
40 mph in 3rd at at the engines peak output...~100% torque...
in fact for the 4 dyno charts I analyzed, it was peak torque...
HP is not a force, it's a measure of the rate of application of force...torque is a force and the instantaneous output of the engine...
although airflow DP is ~ velocity (actually v^2), the main points of pressure drop in an engine are the filter, and more so the throttle, hence the vaccum going to 0 when it's opened...other drops are minor...
and regardless, the engine will inhale ~ the same volume (for a given engine), it will just lose a bit more in pumping losses...
how can I upload an xls spreadsheet?
klauster
Post by klauster » Sat May 23, 2009 10:09 pm
here is mine
rAudiguy
Post by rAudiguy » Tue May 26, 2009 5:45 pm
Has everyone had there print out's now??
thanks
Jim
Current car..... hmmmmm????
RS4 B7 Gone
RS6 C5 Gone
M3 E46 smg Gone
S3 Gone
RED_ROCKET
Post by RED_ROCKET » Tue May 26, 2009 6:02 pm
Still waiting for mine...
993 Gt2 - Mid life crisis
RS4 B5 -(Disappeared)
Q7 - Family wagon (RIP)
PetrolDave
Post by PetrolDave » Tue May 26, 2009 7:18 pm
Don't know if this is OT or not - doesn't the ECU SW restrict the throttle opening to 70% of max in 1st, 2nd and 3rd gears? I think I've read that here and elsewhere.
If so, are results in 3rd gear representative of the actual maximum power output? Wouldn't results in 4th be needed?
pippyrips
Post by pippyrips » Tue May 26, 2009 7:57 pm
rAudiguy wrote:Has everyone had there print out's now??
thanks
Jim
Still waiting on mine.
pippyrips
Post by pippyrips » Tue May 26, 2009 8:07 pm
PetrolDave wrote:Don't know if this is OT or not - doesn't the ECU SW restrict the throttle opening to 70% of max in 1st, 2nd and 3rd gears? I think I've read that here and elsewhere.
Yep, vagcom scans show 51% throttle up until 5500rpm on stock cars, that is why the healthy cars show a jump in power around this mark on the graphs.
In theroy it doesn't matter as you are measuring peak power which in the they get to.
ArthurPE
Post by ArthurPE » Tue May 26, 2009 9:04 pm
if this is true, it would limit power...less air=less fuel=less power...
this would explain why torque makes spec at low rpm, ie, when the air volume is satisfactory, and as rpm's climb, HP tails off...
very interesting...
perhaps what the modified ecu mapping does is allows full throttle in < or = 3rd gear? therefore full power...
pippyrips
Post by pippyrips » Tue May 26, 2009 9:34 pm
very interesting...
Not all mappers do this, there were a few mapped cars at the RR day that delivered 'standard' curves if you know what i mean :?
Weridly, Jim's car seemed to have redeveloped its throttle restriction at the RR day even though it had been removed previously.
I think this is what most people notice when their car has been mapped and the throttle sorted. They don't actually gain many if any more horsepower but it feels like you have as you get more of them early on!
Mine is now fully open in all gears and the difference off the mark is really noticable, its also now very easy to drift the tail on roundabouts :D
bn8959
Post by bn8959 » Tue May 26, 2009 9:35 pm
Still waiting for mine too
2016 C7 RS6 - Panther Black
Previous:
2008 B7 RS4 Avant, Phantom Black
mac4RS
Post by mac4RS » Wed May 27, 2009 9:50 am
Me too...
pippyrips
Post by pippyrips » Thu May 28, 2009 9:11 pm
I gave Paramount a ring yesterday and got mine via email a few hours later. Might be worth doing the same if you are still waiting.
youry
Post by youry » Sun May 31, 2009 1:06 am
We at RS QUATTRO (Belgium) is exactl what we do in our ECU mod, we modify the intak valve limitation in firt three gears, this is huge difference in driving. we don't put the limitation to 100% though as its also a protection for the clutch, but increasing it is a myst ansd to be honest is probably one of the main reasons why an ECU remap is worth it....
more info on www.rsquattro.com
AUDI RS5 B9 (2017-2019)
AUDI A6 AVANT 4G (2012-2016
AUDI RS5 B8 (2010-2012)
AUDI A4 AVANT B8 2.0 TD I 120hp, upgraded to 184ch/442Nm used as daily car (09-12)
AUDI A4 RS4 V8 upgraded to with +35hp/+30Nm) (06-08)
PORSCHE 996 TT upgraded to 500hp/700Nm (05-06)
Users browsing this forum: Google [Bot] and 313 guests
