I was going to have a go with the Supersprint cat bypass pipes. There's not much space under there to put switchable bypass valve. Also Supersprint to a mid pipe without mufflers, so you could run single box on each pipe. Now that would be boomy....perthwaRS6 wrote:Stage 2 remap power peaks around 6700 RPM, same as stock. To push this up needs exhaust and optionally secondary cat bypass. MRCs recommended solution was Supersprint secondary cat bypass pipes and Milltek, then custom engine map and gearbox map to make most of area around 7000 RPM.catfood12 wrote:andy wrote:Now you mention it, what are the pros/cons of a secondary cat bypass? I was thinking that if I did get mine remapped I might as well go the whole hog and make the visit worthwhile but not sure if this introduces any issues?
quote]
Hi catfood,![]()
previous owner of my C6 RS6 sedan had a supersprint exhaust replacing the OEM exhaust- found it too 'boomy' inside with the windows up with the APR map for his liking and went back to standard OEM exhaust FWIW.
Having said that, i most likely will re-invent the wheel and will try an electronic secondary bypass cutout just ahead of the secondary cats.![]()
john
Mod decision
Re: Mod decision
Re: Mod decision
andy wrote:Who are you with out of interest Catfood?
LV.
Re: Mod decision
Thanks fella. With Admiral currently and I think they are quite receptive to mods but good to have a backup.
C6 RS6 Avant in Mugello Blue - sold
BMW M2 LCi
BMW M2 LCi
Re: Mod decision
Admiral were fine with my modded C6
Re: Mod decision
Cheers DK, thought they would be.
BMW M2 LCi
BMW M2 LCi
- scottie1979
Re: Mod decision
Looking at Admiral online and with no mods i am quoted £400. Adding an ECU mod (they have serveral options +5% +10% etc) and selecting +20% ECU power mod, turns my £400 into an unable to quote.
Obviously specific to each person - taking the above into account it is interesting that they have different brackets for ECU (or chip mods as they call it).
Not that im considering buying an RS6 ..... honest
Re: Mod decision
Can someone advise the difference between and MRC Stage one and their stage 2?
Ta
Ta
RS4 B5. Where it all started.
RS6+ Never to be replaced.
Replaced by RS6. I like(d).
Back with C6 RS6
And again C7 RS6
Back with C6 RS6
And again C7 RS6
Re: Mod decision
Fast and faster.bobjebb wrote:Can someone advise the difference between and MRC Stage one and their stage 2?
Have considered asking them? "For power estimates and plots, for Stage 2 and Stage 3 remaps, please email: info@mrctuning.com"
Mod decision
Isn't stage 1 standard off the shelf map and stage 2 is bespoke to the car.
As Bam says, speaking directly to the horse likely to be best plan.
Mod decision
Yes that's my understanding between stage 1 & 2, off the shelf vs custom.
I might call Admiral first though or wait until my renewal is out of the way in October.
BMW M2 LCi
BMW M2 LCi
