Oh pants, car already feeling slower......
Mr Footlong
Re: Oh pants, car already feeling slower......
Post by Mr Footlong » Tue Jan 17, 2012 3:25 pm
Sorry Amar, I am keeping my cats for that exact reason too :(.
Current:
Gone:
Mr V10
Post by Mr V10 » Tue Jan 17, 2012 3:34 pm
No problem, I don't want to do my ones, but will look for another set.
Post by Shoppinit » Tue Jan 17, 2012 3:35 pm
Get some bespoke manifolds and downpipes like bam's. :)
Mr Footlong
Post by Mr Footlong » Tue Jan 17, 2012 3:36 pm
Just get proper 100 cell cats darling, I had forgotten how lovely the turbo spool sounded through them :D. Go big or go home as the saying goes.....
Current:
Gone:
Post by Shoppinit » Tue Jan 17, 2012 3:45 pm
What about the precats though?
Mr V10
Post by Mr V10 » Tue Jan 17, 2012 3:48 pm
I will if you pay for them :)
£1750, just seems too much. I reckon I could have some custom sports cats made up for £6/700
Mr Footlong
Post by Mr Footlong » Tue Jan 17, 2012 3:50 pm
Been there, done that. Add Hayward & Scott to your shortlist if you do that. I have gone to them a few times for bespoke work.
Current:
Gone:
Mr V10
Post by Mr V10 » Tue Jan 17, 2012 3:58 pm
Mr Footlong wrote:Been there, done that. Add Hayward & Scott to your shortlist if you do that. I have gone to them a few times for bespoke work.
I've heard good things about them at least four times in the last week so I definitley will.
Post by bam_bam » Tue Jan 17, 2012 4:08 pm
Hayward & Scott did this for me (silencers with bypass cowel pipes).
Talk to Ian, the double workshop is a testament to all things tubular. If I was to do it all again I'd have just gone full custom, would've been worth the quality and soooo much more tuneful.
Post by chunky79 » Tue Jan 17, 2012 5:26 pm
Shoppinit wrote:What about the precats though?
As ben say's, you should be ok mot time with just the down pipes gutted
Post by chunky79 » Tue Jan 17, 2012 5:29 pm
Shoppinit wrote:I thought the heatsoak was a problem because it raised the air charge temps. The Wagners may help in this respect.
As for the engine itself being hot, theoretically the hotter the engine the better for efficiency - hence the research into ceramic cylinder liners. We need to limit engine temperature for reliability, but in what way would the oil being 130° instead of 90° cause power loss?
It is the charge temp that gets buggered by heat soak. Sure Doug has tried a front mount cooler which worked well.
Surley if there were vents put in the bonnet this would really help flow up past the engine to help but this would then change the flow that the under tray makes :roll:
Post by bam_bam » Tue Jan 17, 2012 5:52 pm
It just needs negative pressure behind the radiator. Significant temp reduction then.
Post by chunky79 » Tue Jan 17, 2012 7:32 pm
No luck with bonnet vents yet luke?
Post by bam_bam » Tue Jan 17, 2012 8:37 pm
chunky79 wrote:No luck with bonnet vents yet luke?
Yeah, 2nd bonnet is ready to go. Just waiting for a justification, it still hasn't got the WM, the Wagners or the final map, yet...
Post by chunky79 » Wed Jan 18, 2012 7:36 am
ooooooooooooooooo, me loooooky forward to pic's of bonnet :bowdown:
You going for wagners then, Have mrc said that they will be required or are you doing a preventative mod??
Users browsing this forum: asgor, Google [Bot] and 83 guests
