Oh pants, car already feeling slower......
- Mr Footlong
Re: Oh pants, car already feeling slower......
Sorry Amar, I am keeping my cats for that exact reason too
Current:
Gone:
Gone:
No problem, I don't want to do my ones, but will look for another set.
Get some bespoke manifolds and downpipes like bam's.
- Mr Footlong
Just get proper 100 cell cats darling, I had forgotten how lovely the turbo spool sounded through them
. Go big or go home as the saying goes.....
Current:
Gone:
Gone:
What about the precats though?
I will if you pay for them
£1750, just seems too much. I reckon I could have some custom sports cats made up for £6/700
- Mr Footlong
Been there, done that. Add Hayward & Scott to your shortlist if you do that. I have gone to them a few times for bespoke work.
Current:
Gone:
Gone:
I've heard good things about them at least four times in the last week so I definitley will.Mr Footlong wrote:Been there, done that. Add Hayward & Scott to your shortlist if you do that. I have gone to them a few times for bespoke work.
Hayward & Scott did this for me (silencers with bypass cowel pipes).
Talk to Ian, the double workshop is a testament to all things tubular. If I was to do it all again I'd have just gone full custom, would've been worth the quality and soooo much more tuneful.
As ben say's, you should be ok mot time with just the down pipes guttedShoppinit wrote:What about the precats though?
It is the charge temp that gets buggered by heat soak. Sure Doug has tried a front mount cooler which worked well.Shoppinit wrote:I thought the heatsoak was a problem because it raised the air charge temps. The Wagners may help in this respect.
As for the engine itself being hot, theoretically the hotter the engine the better for efficiency - hence the research into ceramic cylinder liners. We need to limit engine temperature for reliability, but in what way would the oil being 130° instead of 90° cause power loss?
Surley if there were vents put in the bonnet this would really help flow up past the engine to help but this would then change the flow that the under tray makes
It just needs negative pressure behind the radiator. Significant temp reduction then.chunky79 wrote:It is the charge temp that gets buggered by heat soak. Sure Doug has tried a front mount cooler which worked well.Shoppinit wrote:I thought the heatsoak was a problem because it raised the air charge temps. The Wagners may help in this respect.
No luck with bonnet vents yet luke?
Yeah, 2nd bonnet is ready to go. Just waiting for a justification, it still hasn't got the WM, the Wagners or the final map, yet...chunky79 wrote:No luck with bonnet vents yet luke?
bam_bam wrote:Yeah, 2nd bonnet is ready to go. Just waiting for a justification, it still hasn't got the WM, the Wagners or the final map, yet...chunky79 wrote:No luck with bonnet vents yet luke?
ooooooooooooooooo, me loooooky forward to pic's of bonnet
You going for wagners then, Have mrc said that they will be required or are you doing a preventative mod??
Users browsing this forum: No registered users and 135 guests
