RS6 Resuscitation
Re: RS6 Resuscitation
Post by chunky79 » Tue Dec 09, 2014 3:10 pm
Could very well be the turbo, this would make a rather nice smoke cloud. If it is the turbo, get both done at the same time!
Post by Shoppinit » Tue Dec 09, 2014 3:11 pm
Remove your bottom intercooler hoses to see how much oil is in them.
Post by chunky79 » Tue Dec 09, 2014 3:13 pm
Check the state of the actual coolers as well while there, make sure they aren't leaking.
SuprSi
Post by SuprSi » Tue Dec 09, 2014 3:22 pm
Can turbos leak from the hot side too or just the cold side?
From what I've read these engines are virtually bulletproof so I guess it's quite likely a turbo. :(
sweegie
Post by sweegie » Tue Dec 09, 2014 9:12 pm
Yeah, you can blow a seal on the hot side, letting oil directly onto the turbine wheel. This is pretty hot :)
Recycling dinosaurs for fun
PoP-PoP-BANG
Post by PoP-PoP-BANG » Tue Dec 09, 2014 9:45 pm
I've seen it run and drive before, but never saw any smoke from the exhaust then, although it was quite brief.
It only smokes when driving, not idling.
The garage are going to check the breather pipe and check the turbo pipes to see whether there's any oil in there.
If a turbo had gone, wouldn't it show up in the car fault codes? Because there was no mention of it when I scanned it before it went to the garage.
Are there any other obvious ways to check whether the turbos are the culprit?
The intercoolers did have some black oil stains at the bottom but it looked like a minor amount.
Could it be something to do with the fact that its been sitting for so long? Or all the new parts and valves, etc?
Could it be the cat? Could a load of oil get into them?
stuartph
Post by stuartph » Wed Dec 10, 2014 2:31 pm
I looked at a car last week, on start up it smoked badly and slightly when being driven, my guess was turbos or valve stem seals, maybe more stem seals
Guessing when on boost and higher oil pressure while driving could be forcing oil out of your turbine seals, I'm no expert on these and couldn't ansewer about a breather problem
stuart
PoP-PoP-BANG
Post by PoP-PoP-BANG » Tue Dec 30, 2014 3:24 pm
I hope you're all enjoying the festive season
The right hand side turbo has definitely gone! I'm currently on the hunt for a pair of turbos, with OEM ones from Audi costing around 6k, I need an alternative. I've searched the forum and online, I've found a few German companies on eBay offering new OEM influenced turbos, I don't suppose anyone on the forum has gone down this route and bought such turbos?
The cheaper option would be to remanufacture the turbos but I'm not sure how long they'll last for. Nevertheless, CR turbos are offering to re-furb and hybridise my turbos for 330-390 each, depending on condition, which should apparently increase BHP by 50-80. Has anyone got any experience with refurbished turbos? If so, who did the work? Has it been plain sailing? Or were you thrown overboard?...
I also feel that I should change the gearbox now whilst I've got the engine out, even though the gearbox seems fine, I know it's only a matter of time.
It's not all bad news, now that I'm having to take the engine out, I've decided to milk the opportunity and gone and bought a nice Milltek decat down pipe, with matching non resonated black tip system. Has anyone else fitted the complete system? Does your car pop and bang? *mind the pun* I can't wait to hear the new system!
I've also got some KW intercoolers for £600 from eBay, went with these because they are slightly bigger than Wagner intercoolers and, similar build quality on the welds, especially the end tanks but at a cheaper price than the equivalent Wagners (got the hoses from Wagner though). I don't suppose anyone else on here has fitted these intercoolers?
Mɐʇʇ
Post by Mɐʇʇ » Wed Dec 31, 2014 1:24 am
If the reman is done by a reputable company, I'd have no issue with a reman one. (In fact had a garrett one rebuilt by owen developments, who did a lovely job, earlier in the year)
If it's just seals and otherwise in good order, that's gotta be worth doing?
mik15
Post by mik15 » Wed Dec 31, 2014 9:16 am
2004 RS6 by ABT, madly in love with it, RNS-E, ST coilovers, new TC, 19x9x29 RS4 B7 wheels, non-resonated Milltek w/blk tips, TBC....SOLD - but never to be forgotten!
2004 RS6 ebony schwarz, SE exhaust, 19'' rims - SOLD
'09 RS6 C6 - the great white - now, this means business!
Post by Shoppinit » Wed Dec 31, 2014 9:30 am
PoP-PoP-BANG
Post by PoP-PoP-BANG » Wed Dec 31, 2014 1:34 pm
Cheers for the links. Yeah i saw both of these, but are based overseas which is putting me off.
The condition of my turbos isn't that bad. The left hand side turbo is fine and i think the right hand turbos seal has probably gone so I'll probably go down the route of refurbing the turbos.
Who's the most reputable turbo reconditioner? Who have you guys had your turbos refurbed by? Anyone tried CR Turbos before?
I'll check out Owen developments
ahoooga
Post by ahoooga » Wed Dec 31, 2014 1:39 pm
Fellow called Ben from http://www.theturbounit.co.uk/ in Tamworth is reliable . advertiser over on srs . He's done 1 for me and 2 others for 2 mates over the time. Well worth a phone call and a look at his web site.
Weiß-sechs
Post by Weiß-sechs » Thu Jan 08, 2015 4:44 pm
AET of Wakefield did mine, no complaints whatsoever, here's the spec:
Starting with the orig K04 turbos,
Machined 7 deg cutback to turbine exdcuer to increase flow through the turbine housing
Fitment of K06 billet compressor wheels, 35Lb/min
CNC machined compressor covers to accommodate the hi-flow billet compressor wheels
Fitment of AET motorsport spec 360 thrust assemblies to cope with increased boost pressures
Total seal piston rings fitted to turbine for low back pressure exhaust systems
Ported wastegates for increase boost control at hi boost
14psi Turbosmart IWG75 actuators fitted
VSR Balanced to motorsport spec
pete62
Post by pete62 » Thu Jan 08, 2015 7:37 pm
Weiß-sechs wrote:AET of Wakefield did mine, no complaints whatsoever, here's the spec:
Users browsing this forum: No registered users and 216 guests
