TerraClean RS4 test (FAIL FAIL FAIL)
TonyHayers
Re: TerraClean RS4 test (FAIL FAIL FAIL)
Post by TonyHayers » Fri Jan 18, 2013 11:29 pm
Youngben wrote:confused the car does run with the fuse for the fuel pump taken out? you taken the one out behind the pannel next to the steering wheel? i know this because i did the same when i went on holiday and ran the car until it ran out of fuel in the lines.
*Sigh*. Muppets. My experience today tells me that TerraClean most certainly does not work.
I'm now more concerned why I'm only getting 345hp (350ps?).
Meh, it's way past beer'o clock - I'll worry about it tomorrow :beerchug:
06 Phantom Black Saloon:
^ GONE :cry:
RS6chris!
Post by RS6chris! » Fri Jan 18, 2013 11:40 pm
Whose to say it won't work if a way of getting into the system is found?
There must be a way surely?
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
S4Player
Post by S4Player » Fri Jan 18, 2013 11:46 pm
Dyno dynamics rollers are notorious for reading low I wouldn't worry too much, I made just over 400hp with a supercharger fitted!!
TonyHayers
Post by TonyHayers » Sat Jan 19, 2013 12:05 am
RS6chris! wrote:Whose to say it won't work if a way of getting into the system is found?
It doesn't work in the sense that I wasted half a day farting around with local franchisee, I value my time quite highly :)
If anyone else can be arsed having a go I'm interested to see results, but it would have to be damn impressive evidence for me to drive to a different area to find another franchise. The engineer guy I spoke to at the UK distributor last week was a dick also, sounded like Gareth Cheeseman.
^ GONE :cry:
Madmonkee
Post by Madmonkee » Sat Jan 19, 2013 1:37 am
Why can you not disconnect the fuel feed to the injector rail and plug that straight into the return? Wouldn't need to pull out the fuse then? Plug in this <beep> to the FPR and away you go??
Madmonkee
Post by Madmonkee » Sat Jan 19, 2013 1:40 am
^^ might be tricky on the v8 was just thinking about a 4pot... Ignore
ArthurPE
Post by ArthurPE » Sat Jan 19, 2013 1:43 am
terraclean intake valve cleaner, says manifold off and applied directly on valves
http://terraclean.net/product.php?id=54
via vaccum or intake
http://terraclean.net/product.php?id=16
It is applied using the TerraClean Pressurized Induction Tool through the Air Induction System or through a vacuum line.
thru the fuel system method should not do much, as DI is the root cause of the deposits, ie, no fuel on valves to wash clean, but it is injected into the cylinder
ArthurPE
Post by ArthurPE » Sat Jan 19, 2013 1:47 am
terraclean procedure for the RS4
http://terraclean.net/app_guide2/index.php
2007/audi/rs4
brings up the instructions
shows exactly how to do it
CLEANING PROCEDURES
Year:2007 Make:Audi Model:RS4 Engine:4.2L, V8 DOHC, VIN U (BNS) Fuel System:Bosch ME-9
Fuel Pressure:65-94 psi
Gizmo68
Post by Gizmo68 » Sat Jan 19, 2013 1:58 am
It’s unfortunate that you took it along to a bunch of muppets Tony who frankly should have known better (they should of researched the RS4 before you got there).
Although without a borescope down the plug hole to take before and after photos I feel you would have left feeling a bit cheated away, sure you would of seen some increase, but I feel the majority of the carbon build up would still have been on the back of the inlet valves.
VCDS HEX+CAN owner - covers all VAG cars (PM me if you require VCDS coding in Kent)
sonny
Post by sonny » Sat Jan 19, 2013 2:02 am
This was my understanding all along, but thought maybe you guys knew something that I didn't. :?
TonyHayers
Post by TonyHayers » Sat Jan 19, 2013 9:35 am
I think adsgreen had a point on this though iirc. If the deposits have been made due to combustion, then the same combustion could deposit something else?? Dunno, I'm a complete novice in such matters. But like I said in the first post, I'm pretty skeptical it would make a significant difference. Thought it would be interesting to do a before/after test.
LOL that Arthur found instructions for the RS4. I think I may have had a lucky escape with these guys. Checked my engine bay to make sure everything went back where it should have been.
^ GONE :cry:
TonyHayers
Post by TonyHayers » Sat Jan 19, 2013 9:38 am
Gizmo68 wrote:It’s unfortunate that you took it along to a bunch of muppets Tony who frankly should have known better (they should of researched the RS4 before you got there).
Amen to that ^
^ GONE :cry:
STURS4
Post by STURS4 » Sat Jan 19, 2013 12:49 pm
Meh, it's way past beer'o clock - I'll worry about it tomorrow :beerchug:[/quote]
The guy who owned my car before me had a dyno test before having the heads removed and cleaned by hand.it ran 355hp before the clean then 405hp after.this is my second RS4 and its MUCH faster than the first,can really tell the difference.
when you get your x-pipe done dont suppose i could have a listen to it could i?thinking of doing it but im unsure if il like the sound or not.
TonyHayers
Post by TonyHayers » Sat Jan 19, 2013 1:52 pm
STURS4 wrote: The guy who owned my car before me had a dyno test before having the heads removed and cleaned by hand.it ran 355hp before the clean then 405hp after.this is my second RS4 and its MUCH faster than the first,can really tell the difference.
Yeah, sure, are you near Leeds?
^ GONE :cry:
sakimano
Post by sakimano » Sun Jan 20, 2013 6:50 am
Kudos for trying. I'd have happily paypal'd you a tenner should you do it again.
Also, the dyno dynamics... Does that measure wheel horsepower or crank horsepower? If it's crank you should do an Arthur test (official name) so we can see if it's really that dire (-80hp) or if the car just didn't like the dyno.
I can tell you that those crank numbers are like a stock b7 s4 and to cover 5000 rpms in third would take the s4 about 10 seconds whereas it takes the rs4 a little over 8
Users browsing this forum: No registered users and 157 guests
