my car is broken :(
Angelo_Amato
- 1st Gear
Same with BMW AFAIK, and yet the cost is so much lower. A M3 CSL, with the most fragile of the BMW engines & a fancy rear axle/gearbox etc, costs less than a grand. And is the M5/6 V10 500ps engine not more complicated than a very long running V8 4.2 from Audi?. Remember DRC is covered up to 5 years by Audi and the quattro system is robust and rather well established for Audi.aka_dk wrote:the audi extended warranty is provided by Mondial. Its the same warranty that is provided in year 3 of ownership
So do Mondial have more faith in BMW than in Audi, or do Audi contribute less to the warranty fund than BMW.
There are a lot of people on RS246 who do not plan to to renew their warranty, or plan to change cars and so are not interested. This makes our negotiation more difficult. We really need a 100 people on this forum (mainly RS4, S4, RS6,S6) to sign up and then we have a chance of getting the warranty cost reduced to say £1,200 per annum.
None of us are 1st cousins of Audi, we are their customers and we should make our just representations, as we vote with our wallets in buying their cars. The campaign on DRC worked for a reason, it was just and it was many of us.
Some on here are not interested purely because as a "risk assessment versus £1650 cash layout" the figures dont stack,this thread would go against mine and others theory i have to admit,but its almost an isolated case,ive been on here since the b7 was born and only heard of a couple of major engine failures which is very good given the number of cars etc I see nothing to worry about with the b7 that warrants 1650,audi are being very greedy trying to make alot of money on this product,the only way is to vote with your feet! walk away from the warranty at that price and more importantly walk away from the dealerships for servicing and repairs,the big bills are from the big labour rates,a good indy will do more for less and possibly a better job if they see more of these particular cars.The warranty is very expensive for partial cover on the car,the "all component" is laughable,you will not be protecting yourself from all bills. To the OP i would imagine a new engine will be required as any foreign objects in the bore will have no doubt damaged them and probably the head aswell
Good points.lengster1 wrote: nothing to worry about with the b7 that warrants 1650,audi are being very greedy trying to make alot of money on this product,the only way is to vote with your feet! walk away from the warranty at that price and more importantly walk away from the dealerships for servicing and repairs,the big bills are from the big labour rates,a good indy will do more for less and possibly a better job if they see more of these particular cars.The warranty is very expensive for partial cover on the car,the "all component" is laughable,you will not be protecting yourself from all bills.
Audi are being silly for once people give up the warranty, there will be no requirement to use their expensive dealer network.
Teutonic_Tamer
- 2nd Gear
Re: my car is broken :(
One litre - it is an 'industry standard' (which most manufacturers now follow).Sims wrote:Does anyone know the difference in quantity of oil between minimum and maximum mark.
Only on the OEM exhaust and 'associated' fittings . . . .Sims wrote:Does a Miltek affect the warranty?
Sean - Independent Motor Vehicle Tech (ret'd)
'07 Audi B7 RS4 (with ceramic brakes) - WOW!
'06/7 VW Golf Mk5 GTI 2.0T FSI DSG 5dr
'03 Audi B6 S4 4.2 V8 6sp man (gone)
Teutonic_Tamer
- 2nd Gear
Re: RE: Re: my car is broken :(
Agreed. I check mine daily . . .aka_dk wrote:Best to check out oil more often me thinks..
It should - but they arn't particularly reliable. On my B6 S4, I once checked my oil and it was about ½inch BELOW the minimum - yet there was no warning in the DIS!!!aka_dk wrote:..but shouldnt the low oil warning come on when it needs a litre?
Local Audi garage admitted they were not particularly reliable and changed it
Teutonic_Tamer
- 2nd Gear
You have to check the oil in the RS4 when the engine is HOT. Checking it when cold can give misleading readings on the dipstick.iana74 wrote:A quick check takes 2mins every now and again or before a significant journey.
The owners manual clearly states to check when hot.
A mistake that many make! ideally it should be checked as part of a "weekly" check, along with other fluids and tyre pressures.Teutonic_Tamer wrote:You have to check the oil in the RS4 when the engine is HOT. Checking it when cold can give misleading readings on the dipstick.iana74 wrote:A quick check takes 2mins every now and again or before a significant journey.
don't think I advised checking it cold!? Made the assumption people know to check oil when warm.....Teutonic_Tamer wrote:You have to check the oil in the RS4 when the engine is HOT. Checking it when cold can give misleading readings on the dipstick.iana74 wrote:A quick check takes 2mins every now and again or before a significant journey.
Teutonic_Tamer
- 2nd Gear
OK - fairy nuff. I only highlighted it because when you said "before a significant journey" - that could be construed as the car being stone cold - afterall, tyre pressures and coolant need checking stone cold.iana74 wrote:don't think I advised checking it cold!? Made the assumption people know to check oil when warm.....Teutonic_Tamer wrote:You have to check the oil in the RS4 when the engine is HOT. Checking it when cold can give misleading readings on the dipstick.iana74 wrote:A quick check takes 2mins every now and again or before a significant journey.
Users browsing this forum: Google Adsense [Bot] and 334 guests
