SOLD Genuine C7 RS6 20x9.5j et21 wheels NO TYRES
Re: Genuine C7 RS6 20x9.5j et21 wheels with tyres
I think the outside edge is a bigger issue than calipers in this instance. Running the equivalent of 15mm spacers in the front is quite a lot to stick out and even if it doesn't rub (which it probsbly will if lowered) it might stick out too much from a visual point of view, 15mm spacers on the front is too much for me. Also if you use narrower tyres as shown above you will increase the gap between the tyre and the arch which has the effect of looking like you've raided the suspension meaning an even greater need to lower than before.
Mike, you're forgetting that the centreline of the wheel is only 8mm further out. The wheel is a half inch wider than OEM too, hence the face of the wheel 14mm further out, but the inside of the wheel is only 2mm further out...so the tyre gets stretched a bit.
This is 19x9.5, effective ET20, on 255/35/19 tyres. No rubbing up front at all, but it did rub at the back right corner.
2007 RS4 B7 Avant
- Surrey Sam
Meh...regardless.
They're just cool wheels which are overpriced. Sets with worn OEM tyres have previously sold for around £500.
I am happy to measure the inner face.
SurreySam, I have seen no sets for £500 with tyres, even if they're worn. Without getting into an argument, I think you have no right to suggest they're overpriced, considering what genuine oem wheels tend to sell in general.
Have not seen any go for £500 would be interested to see them, you can not get a set of RS6 C6 Peelers for that priceSurrey Sam wrote:Meh...regardless.
Yea i agree. I've been looking for a while and they have all been 1300+. Various condtions, with and without tyres etc.
- MartayMcFly
- 5th Gear
I don't think I've ever seen a set of OEM 20" wheels go for £500, even without tyres that'd be a bargain.
2001 8L S3 - sold
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
2015 8V RS3 Stage 3 - sold
2017 Alfa Giulia Quadrifoglio
2008 8P2 S3 - sold
2007 B7 RS4 - sold
2016 C7 RS6 - sold
Is it possible to get a pic of the hub face. The depth I'm interested in. I have found somewhere who can take off a few mm
2007 RS4 B7 Avant
Dean is this for a B8? I've seen them before on a B8 so don't think there is a issue with fitment.DeanoC wrote:Is it possible to get a pic of the hub face. The depth I'm interested in. I have found somewhere who can take off a few mm
Yes Mike. I'm not comfortable with 11mm following a measure upMikeFish wrote:Dean is this for a B8? I've seen them before on a B8 so don't think there is a issue with fitment.DeanoC wrote:Is it possible to get a pic of the hub face. The depth I'm interested in. I have found somewhere who can take off a few mm
Give me a day or two and I will provide the necessary measurements for people.
Regarding value of these - if it helps - I bought a set of 4 alloys with new tyres from dealer off a delivery mileage car (owner went aftermarket from new) for £1600 delivered.
Perhaps I was lucky.
They are great wheels - forged, strong and amazingly light for an OE wheel.
Here's the steel (i.e. non-ceramic) caliper measurements for the B8 which I tend to use when buying alloys...Adam L wrote:Give me a day or two and I will provide the necessary measurements for people.
My current summer alloys are a similar 20 x 10 ET20 fitted 265/30 R20 though I DID experience rubbing at rear under load and during spirited cornering. This was overcome by introducing a -2 degree camber which is, apparently, the maximum negative adjustment. I haven't notice any significant uneven tyre wear as a result. They are nice & flush.
B8 RS4 in Daytona Grey
A1 S line Black Edition (Mrs')
Recent Past:
BMW 325i M Sport Coupe (E92), BMW Alpina D3 (E90), A4 DTM Quattro (B7), BMW M3 (E46)
Recent Past:
