Vibrating on Full Lock
Harris.
Re: Vibrating on Full Lock
Post by Harris. » Fri Mar 11, 2016 9:07 pm
Did you resolve this , mine has started doing this again and feels terrible at car park speeds .
Maybe thinking about H&R springs ?
Surrey Sam
Post by Surrey Sam » Fri Mar 11, 2016 10:53 pm
How do you think that will help resolve the problem?
Harris.
Post by Harris. » Fri Mar 11, 2016 11:14 pm
Just a thought Sam as mine is only drivers side not passenger . I've double checked all the new arms are tight and fitted correctly which they are . Tyres are as good as new and at the correct psi .
My thoughts were to drop the front 20mm to see if it helps at all ? or Front ARB bushes ?
Surrey Sam
Post by Surrey Sam » Fri Mar 11, 2016 11:31 pm
After all that work you've put in to the car I'd get a reputable place to do a full, 4 wheel alignment on the car. Then see where you're at with the problem.
Lowering the car is just going to throw the geometry out even further.
Harris.
Post by Harris. » Fri Mar 11, 2016 11:48 pm
I had the Hunter 4 wheel alignment done sam ,they did say take it back after 500 miles for a free Re check so may run it there tomorrow,but then if others are doing the same it may just be the way the rs4 is? It also has a slight knock when steering left to right on the spot so I'll ask them to check the steering rack bolts too
Surrey Sam
Post by Surrey Sam » Fri Mar 11, 2016 11:58 pm
Harris. wrote:I had the Hunter 4 wheel alignment done sam ,they did say take it back after 500 miles for a free Re check so may run it there tomorrow,but then if others are doing the same it may just be the way the rs4 is? It also has a slight knock when steering left to right on the spot so I'll ask them to check the steering rack bolts too
That's a very worthwhile thing to check out, although the steering rack bolts are a pain to see properly. Certainly worth checking out though, just so that you can eliminate them from the list.
Harris.
Post by Harris. » Sat Mar 12, 2016 12:03 am
They did ask when I had it done If I had the ss+ and I wasn't sure so they adjusted to the normal settings.
Surrey Sam
Post by Surrey Sam » Sat Mar 12, 2016 12:18 am
Have a look at your build Sticker:
2ME = Supersport Suspension
2MC = Standard Sport Suspension
One is located on the inside front cover of your service history booklet.
FaisalJ
Post by FaisalJ » Sat Mar 12, 2016 12:23 am
Surrey Sam wrote:
chunky79 wrote:
Surrey Sam wrote:Is the problem like the car is under steering at car park speeds, and you’re getting a front tyre bounce/scrub sensation through the wheel?
This ^^^^^. This is normal.
Although it does become more prominent, when the tyre tread depths are low and/or toe alignment out of spec.
I think tyres and tyre depth make a difference as Sam points out.
I never noticed this until I swapped wheels for a 20" set with very worn continental sportcontact 5's (255/30/20). Only really when I come off my drive, downhill onto the road, and have to turn sharply. This is when it was most prominent.
Those tyres were swapped within a couple of weeks for new ones of the same type. Making that same manoeuvre, the steering ping/vibration was less noticeable but still there.
However, with eagle f1 255/35/19's, I don't notice it at all.
I actually had a similar thing but much worse in my b8 a4 2.0T Quattro - that issue was well documented and attributed to a power steering hose that needed replacing.
All very weird, but I've stopped worrying about it.
2007 RS4 B7 Avant
Harris.
Post by Harris. » Sat Mar 12, 2016 9:33 am
Surrey Sam wrote:Have a look at your build sticker:
Mine has 2mc, thanks sam
Harris.
Post by Harris. » Sat Mar 12, 2016 6:39 pm
Cars been and had the 500 mile re check , everything was fine and where it should be .
The guy in the Pirelli dealer started laughing when I mention what the car was doing , he said its the tyres and not to worry . he notices it on a fair few cars that go there .
While my car was in there , jet tyres Benfleet I took a short walk to the petrol garage and notice a very clean B7 RS4 on the drive in silver !!! Not seen one before looked :bowdown:
Post by MikeFish » Sat Mar 12, 2016 8:19 pm
Is there a guide to checking / changing these bolts? Everytime I book the car in for work I ask for the bolts to be checked / changed but always come back the same, so I bought the 3 bolts, just need to figure out the easiest way of changing them.
I looked at ELSAWIN but it describes it as part of changing the whole rack so mentions removal of all pipes etc so I'm not sure how much of it is necessary just to change the 3 bolts.
Harris.
Post by Harris. » Sat Mar 12, 2016 8:33 pm
Sam did post a picture of the bolts along with there location. To be honest Mike I just left them to it today .
Surrey Sam
Post by Surrey Sam » Sat Mar 12, 2016 8:36 pm
No 'How To' that I recall Mike as I never got far along in the process. Think I could only get onto one of them from the engine bay so decided to Jack it up onto axle stands where I would then remove the wheel arch liner to gain access to another bolt. In doing so, I found out that the wheel bolts on one wheel were loose, so it ended up being a quick fix.
The_Coat
Post by The_Coat » Sat Mar 12, 2016 9:34 pm
Harris. wrote:Cars been and had the 500 mile re check , everything was fine and where it should be .
Seen that silver saloon myself, it never seems to move.
RS4 Avant - Misano Red
