To VAG-Com users, FATS times database for the Euro S4s
MarkB
Post by MarkB » Thu Nov 30, 2006 10:49 am
SimonS4MTM wrote:So i finaly got around to doing my first FATS runs.
I logged channel 002.
My first time was 5.02, and my second time was 5.14.
How does that sound?
Good time, you're just running a map and exhaust aren't you? Still running 17 inch wheels also aren't you?
Mark
SimonS4MTM
Post by SimonS4MTM » Thu Nov 30, 2006 10:59 am
That's right Mark, plus holes in the airbox.
Well looked after and plenty of tlc.
MarkB
Post by MarkB » Thu Nov 30, 2006 11:05 am
Were you in the car alone in the car when you did the fats run?
Mark
SimonS4MTM
Post by SimonS4MTM » Thu Nov 30, 2006 11:32 am
Yes, I was alone. I didn't take anything out however. Also in the dark with lights on, heated rear screen on and air-con on. Plus a 240V power pack to run the laptop 8)
MarkB
Post by MarkB » Thu Nov 30, 2006 12:05 pm
Mine with catback Milltek, AMD map and hole in Airbox gave 5.75secs but I'm also running 18's.
Opening up the Airbox didn't seem to make much of a change in my time if any!
Mark
SimonS4MTM
Post by SimonS4MTM » Thu Nov 30, 2006 1:00 pm
Is that the normal difference for 18's.
MarkB
Post by MarkB » Thu Nov 30, 2006 1:05 pm
I think mine a little slow but I know it is a disadvantage and 19's are even worse.
Have you posted it on the MRC fats page?
Mark
SimonS4MTM
Post by SimonS4MTM » Thu Nov 30, 2006 1:11 pm
Yes, I put it on there earlier. I think I may have made an error with my torque figure though.
MarkB
Post by MarkB » Thu Nov 30, 2006 1:13 pm
Just been looking, your time looks in the right ball park doesn't it?
Mark
SimonS4MTM
Post by SimonS4MTM » Thu Nov 30, 2006 1:14 pm
Yes I think it does.
Though it appears to have a faster fats time than some other cars with gutted pre-cats
MarkB
Post by MarkB » Thu Nov 30, 2006 3:53 pm
Olie's car was giving slow times which was mainly down to his 19" wheels and Leon is carting his own mobile disco around with hime so I would say your looking good.
Jimbogrey and Shineydave are returning similar times to you and both are standard bar a map.
Mark
CliveH
Post by CliveH » Thu Nov 30, 2006 4:03 pm
so why is mine so "slow"...? :shock: :( (other than the FAT driver :lol: )
Clive
MarkB
Post by MarkB » Thu Nov 30, 2006 4:28 pm
CliveH wrote:so why is mine so "slow"...? :shock: :( (other than the FAT driver :lol: )
It's your RS4 bumper scooping up to much air at the front ;)
Did they not find anything wrong with your cam timing when your belt service was done? Some cars are just slower than others. Just lucky or unlucky I guess....
Mark
oliew
Post by oliew » Thu Nov 30, 2006 4:53 pm
hey :)
yeh 19's defo slowed me down loads!
if i disconnect the battery to clear any stupid ecu rubbish, tb align and do a run then i get 4.75 seconds and full boost practically to 5000rpm with a 100mbar drop to redline then........ if i drive round for a week tootling to work etc. my boost drops to about 15psi max in 3rd gear but i get crazy 30deg timing at redline and still get 4.75 fats. lest boost more timing same fats!
i want k04s to get under 4secs now ;)
S4 B5 - MRC
CliveH
Post by CliveH » Thu Nov 30, 2006 5:29 pm
MarkB wrote: It's your RS4 bumper scooping up to much air at the front ;)
hehe :lol:
MarkB wrote: Did they not find anything wrong with your cam timing when your belt service was done?
No, Doug didnt mention anything, (although I haven't done a FATS run since)
Must just be "unlucky" :(
Clive
Return to “DTC / VCDS”
