light and strong Audi R8 V8
Models: V10 plus, GT, GT Spyder, V8 Limited Edition, Exclusive Selection Edition, China Edition and LMX
4.2 V8 32v Naturally Aspirated - 414 bhp (2007-2011) - 424 bhp (2012-2014)
5.2 V10 40v Naturally Aspirated - 518 bhp (2012-2014) - 542 bhp (Plus 2012-2014) - 562 bhp (LMX 2012-2014)
5.2 V10 40v Naturally Aspirated - 533 bhp (2015-)
5.2 V10 40v Naturally Aspirated - 602 bhp (Plus 2015-)
Speedr8
Re: light and strong Audi R8 V8
Post by Speedr8 » Mon Dec 22, 2014 5:48 pm
Hi
The Bank selective allocation of air is also continued in the air filter box.
Tom
adsgreen
Post by adsgreen » Mon Dec 22, 2014 8:31 pm
not sure on why the bank selective blanking of the air intake.
the firing order is 1–5–4–8–6–3–7–2.
the 8-6 and 3-7 share the same bank and if the intake is blanked off then you may have more air stealing from near cylinders.
some manufacturers with separate air intakes like ferrari have a firing order that doesnt overlap on one bank.
for the 360 its 1-8-3-6-4-5-2-7
Speedr8
Post by Speedr8 » Tue Dec 23, 2014 8:06 am
Hi
In fact, engine the cylinder bank changes the ignition, at the Ferrari V8.
The Audi R8 V8 looks for this purpose worse, but an experiment is it worth.
The performance and torque curve will show, whether one complete separation
of the cylinder banks, here a degree of efficiency increase brings.
Important for me is, that the swinging tube (Intake manifold ) forced induction functions
correctly and also a resonance charging is carried out via the separate air filters.
(Throttle valve to entry Side Blade)
Tom
Speedr8
Post by Speedr8 » Mon Dec 29, 2014 6:06 pm
Hi All
The intake side was treated enough and this time the exhaust port side.
Here I show the outlet port series with gasket, exhaust big passage with seal serie,
then to the exhaust manifold of the Audi RS5 and also the series exhaust manifold.
On the exhaust port size the RS5 you can when RS4 B7 or R8 V8 unfortunately not expand,
because the compressed air duct for the secondary air had no more wall
Outlet channel series with seal series
Expand exhaust port the seal size serie
Outlet channel widened with RS5 exhaust manifold gasket
RS5 manifold gasket on the RS5 exhaust manifold
Series seal on RS4 B7 or R8 V8 manifolds
RS5 seal size on B7 RS4 and R8 V8 manifolds
Tom
Speedr8
Post by Speedr8 » Wed Jan 14, 2015 8:22 am
Hi
Cylinder head two is finished. After 12 hours of work, the entrances are now in contour and finish, ready
Series
contour
Finish
And here the view from direction the pistons into the entrances.
Man sees now beautiful as in a big way in the inlet Port became and
how much material still from the swinging-tubes must out be gotten!
Tom
Speedr8
Post by Speedr8 » Sun Jan 25, 2015 11:36 am
Hi
Tom
classba
Post by classba » Sun Jan 25, 2015 11:42 am
Nice work Tom... when will it be put back together again?.
Speedr8
Post by Speedr8 » Sun Jan 25, 2015 6:07 pm
Hi
the assembly it is out carried.
The inlet manifold must still be adjusted that fits it perfectly.
Tom
Speedr8
Post by Speedr8 » Sun Apr 05, 2015 8:09 am
Hi
Finish ! :jump:
Tom
classba
Post by classba » Sun Apr 05, 2015 9:21 am
Well done Tom... what is the crank power and torque?.
Speedr8
Post by Speedr8 » Sun Apr 05, 2015 10:17 am
Hi
502 phb and 386.48 Ibft
Tom
Speedr8
Post by Speedr8 » Wed Apr 15, 2015 2:41 pm
Hi
Nothing more grumble, the + 29HP and + 24NM were unexpected ? :boots:
Tom
Speedr8
Post by Speedr8 » Tue Apr 28, 2015 5:51 pm
So friends of tuning.
Since engine power (509PS) is achieved without sharp camshafts, was planed a refacing the camshafts.
There are not many people, who can regrind for the drag lever drive, a new camshaft form.
Which is now no longer necessary, since a sharper drag lever via other valve timing with more valve lift can be obtained.
The 530PS come within reach :rocker:
Tom
Post by bam_bam » Wed Apr 29, 2015 9:38 am
Good for you.
classba
Post by classba » Wed Apr 29, 2015 11:10 am
Yes good for you BUT more cam lift and timing will move the power band even further up the rev range making it more un drivable. My R8 GT is pushing out 612PS/606nm with an exhaust, air filters and custom ECU map and remains totally drivable.
Hat off to you Tom for tuning the V8 to the max but my opinion remains.... you would be better off tuning a V10 instead.
Good luck
Return to “R8 Coupé / Spyder (Typ 42) 2007-”
