Tyre time...!
2.5 I5 20v TFSI - 335 bhp
P_G
Re: Tyre time...!
Post by P_G » Wed Oct 10, 2012 10:53 pm
Looking at the configurator you can get the 255/225 front / rear combo on both 8J and 8.5J rims. Would it be that bad if you had 255 front and rear?
nicholas
Re: Tyre time...!
Post by nicholas » Wed Oct 10, 2012 10:58 pm
P_G wrote:Looking at the configurator you can get the 255/225 front / rear combo on both 8J and 8.5J rims. Would it be that bad if you had 255 front and rear?
255 at the front and rear won't reach the effect we're talking about.
Wider tire at the front eliminates understeer..
Leave the rear ones 225.
Dave_Hedgehog
Re: Tyre time...!
Post by Dave_Hedgehog » Thu Oct 11, 2012 4:30 am
the description gives that impression but if you mouse over the two rows of wheels 255s are all 8.5J
im glad i got it thou :biggrin3:
Dave_Hedgehog
Re: Tyre time...!
Post by Dave_Hedgehog » Thu Oct 11, 2012 4:34 am
JonG wrote:
nicholas wrote:I would go for:
255/35/19 front
225/35/19 rear
Thats a big difference in rolling diameter front to rear :shock:
i hadnt thought of this
this is my 255 8.5J v 235 8J (as a potential winter tyre)
207.69 v 203.29
not to bad, i could live with that for a winter wheel
Dave_Hedgehog
Re: Tyre time...!
Post by Dave_Hedgehog » Thu Oct 11, 2012 4:44 am
comparing 255 front to 225 rear and stock 235 front to 225 rear
P_G
Re: Tyre time...!
Post by P_G » Thu Oct 11, 2012 8:36 am
255 at the front and rear want reach the effect we're talking about.
I don't qute follow that logic?
255 tyres were put on the front because as it was seen that the grip offered over 235 was signnificant enough to warrant it. Much like us RS4 owners will put on 275/30 rather than 255/35 and have seen better turn in grip, part of the understeeer elminaton solution. RS3's are Haldex driven so predominantly front wheel drve so what grip the rears have should not have an adverse effect on the fronts i.e. put a wider tyre on the rear = more grip and the back = does not induce understeer. As for rollng radius, the speedo measures off the front axle IIRC and if the difference is <5% it shouldn't damage the Haldex.
I just find it a bit of an odd set up?
Dave_Hedgehog
Tyre time...!
Post by Dave_Hedgehog » Thu Oct 11, 2012 11:15 am
255 tyres were put on the front because as it was seen that the grip offered over 235 was signnificant enough to warrant it. Much like us RS4 owners will put on 275/30 rather than 255/35 and have seen better turn in grip, part of the understeeer elminaton solution. RS3's are Haldex driven so predominantly front wheel drve so what grip the rears have should not have an adverse effect on the fronts i.e. put a wder tyre on the rear = more grip and the back = does not induce understeer. As for rollng radius, the speedo measures off the front axle IIRC and if the difference is <5% it shhouldn't damage the Haldex.
It's also about the balance between front and rear axel not just individual axel grip. increasing the rear grip will induce more oversteer on the limit
Thats why some mid engined cars come with different sizes front and rear, I think our mr2 roadster had 16s on the front and 17s on the rear, I seem to remember the early NSX had a very odd tyre configuration
RSphantom
Re: Tyre time...!
Post by RSphantom » Thu Oct 11, 2012 4:10 pm
I might be talking out of my :assflash: but does it have something to do with the width on the rears as well. I think 255's on the rears might cause a far bit of rubbing???
2019 RS3 4 door - Gone
nicholas
Re: Tyre time...!
Post by nicholas » Thu Oct 11, 2012 11:28 pm
RSphantom wrote:I might be talking out of my :assflash: but does it have something to do with the width on the rears as well. I think 255's on the rears might cause a far bit of rubbing???
:bash: omg, you don't put 255 on the rear..... RS3 is a understeer car - you need to have wider tyre on the front...
Gasman
Re: Tyre time...!
Post by Gasman » Fri Oct 12, 2012 1:10 pm
Here's a question now...on a haldex quattro, should all 4 tyres be changed at the same time, or can "odd pairs" run without issue?
Have managed to source a reasonable price for the Michelin SuperSports but have about 3-4mm tread on the rears. Question is do I run a Michelin/Conti combination or all michelin?
Dave_Hedgehog
Re: Tyre time...!
Post by Dave_Hedgehog » Sat Oct 13, 2012 5:25 am
Gasman wrote:Here's a question now...on a haldex quattro, should all 4 tyres be changed at the same time, or can "odd pairs" run without issue?
you can happily run different tread depth front to rear on quattro, because of the odd tyres there is a difference out of the box
if your basing on reviews im surprised your all not going for pirrelli p zeros which hammered everything in last months EVO tyre test
http://www.tyrereviews.co.uk/Article/20 ... e-Test.htm
PetrolDave
Re: Tyre time...!
Post by PetrolDave » Sat Oct 13, 2012 10:41 am
Dave_Hedgehog wrote:if your basing on reviews im surprised your all not going for pirrelli p zeros which hammered everything in last months EVO tyre test
The big problem with P Zeros is that they are a very soft compound and wear out really fast (at least 50% quicker than any other tyre on a B7 RS4 in my experience) so they review well in a short tyre test but in the real world they go "off" very quickly. I will NEVER fit P Zeros to my RS4 despite them being what the factory fitted.
turbo roro
Re: Tyre time...!
Post by turbo roro » Sat Oct 13, 2012 8:21 pm
do you all take 18" wheels for winter ? anyone been drivinf on snow with the 19" ?
Dave_Hedgehog
Re: Tyre time...!
Post by Dave_Hedgehog » Sat Oct 13, 2012 9:06 pm
turbo roro wrote:do you all take 18" wheels for winter ? anyone been drivinf on snow with the 19" ?
most people in the uk dont run winter wheels or tyres
JonG
Re: Tyre time...!
Post by JonG » Sat Oct 13, 2012 9:13 pm
nicholas wrote:
255/35/19 front
225/35/19 rear
Big, but for the RS3 it's for the better. There even is a wheel upgrade package with such configuration.
Thats too big a difference in rolling diameter IMHO
I note that the Audi upgrade package has 255/30/19 tyres on the front and not 35 profiles, presumably to keep the rolling circumferences similar front to rear.
http://www.audi.co.uk/content/dam/audi/ ... rtback.pdf (page 24)
Audi RS3 in Daytona Grey, 7sp S-Tronic, Sept 2012.
Users browsing this forum: No registered users and 159 guests
