Drc issues- car booked in
brettRS4
Re: Drc issues- car booked in
Post by brettRS4 » Wed Feb 08, 2012 9:57 pm
Just been reading a thread on another forum about drc, it said that all rs4's have been recalled by letter for drc replacement, how come Audi uk is not the same? They were saying the replacement shocks have been improved?? Also this was going on until 2012. It's crazy that the uk is not the same.
adsgreen
Post by adsgreen » Wed Feb 08, 2012 11:47 pm
Us consumer law is a wee bit stronger than uk. I think they have specific mention that if x proportion of sales have the defect its a recall (or something like that)
Or it's just the threat of the financial risk if you get a class action suit...
Personally I think a full on recall is ott as te failure rate and implications of a failure are not high enough.
However on the other hand I don't think there should be any resistance to replacing a defective shock FOC
(iyswim)
P_G
Post by P_G » Thu Feb 09, 2012 1:06 am
brett123 wrote:Ok thanks guys I will see what they say on Saturday, I don't suppose anyone knows who has the Ver 2 system?? I wonder what they would charge for this service?
Brett, Tyneside have the Gen II DRC tool as they did my car with it some 3 years ago. It is shared between the North East dealers who are all the same group. Could also be the CV boot joint, mine split and needed replacing shortly afer my DRC was replaced and I thought DRC had failed again.
Dave7
Post by Dave7 » Thu Feb 09, 2012 6:19 pm
Brett,
I posted at the beginning of this thread saying that I had a similar problem. I have just had Audi pressure test my system and it was low.
As a result that are replacing the 2 front shocks on the good will scheme as this is where the noise is coming from. they also said that just before it hits its 5th b day to come in and they'll pressure test it again for free and if low they'll replace the rears.
Its all about pressure, if its low then you have a problem. If they offer to recharge it that might just prolong your problem as it will lose the pressure again surely.
Get them to test it. It also very much depends on the dealer, it shouldn't but it does.
Get the whip out! :FIREdevil:
56 B7 RS4 Saloon in Sprint with Black Optics, Privacy Glass, Buckets and FBSW
O
brettRS4
Post by brettRS4 » Sat Feb 11, 2012 11:35 pm
Just an update. Picked car up today they told me they cannot hear any noise and everything looks ok underneath. I took the workshop manager out first speed bump knocking noise he said he could not understand how the technician never picked it up! I think he just had a spin about at my expense. It did it all the way on the little drive. He was very reluctant to try goodwill saying where is it end locating the problem? He had just told me all bushes and ball joints looked fine, which only leaves the shockers. In the end he is going to try Audi uk on Monday. I'm holding they come through ok, the car has had all work done through Audi. I hope they come through ok. I will keeps you updated when I hear from them. Fingers crossed....
adsgreen
Post by adsgreen » Sun Feb 12, 2012 8:29 am
Does it make a noise if you wiggle the steering wheel with the engine off?
(might need to be quite 'vigourous')
brettRS4
Post by brettRS4 » Sun Feb 12, 2012 1:06 pm
Hi ads I've just tried it yes it does make a noise when engine is off. What could this mean? Tyne side Audi are trying goodwill on front shockers tomorrow anyway but what could this noise mean? Should it not make any noise wiggling the wheel?
RS6chris!
Post by RS6chris! » Sun Feb 12, 2012 6:37 pm
My DRC has never failed or leaked at all...
However it has ALWAYS knocked going over speed bumps???....i took mine to Teesside Audi when it was still under warranty....they checked it out and all was well...even showed me all shocks up on ramps with wheeels off..all bnone dry and ok...although it still knocks over speedbumps..
Think its just the way it is im afraid??
RS6 C8 carbon black(merlin)
Panamera Turbo S e hybrid
RS6 C8 launch edition
R8 V10 plus
C7 RS6 PE dynamic pack plus
C7 RS6
Porsche Panamera Turbo
C6 RS6 AVANT
RS4 B7
Golf R32 mk 5
BMW M3 E46
Golf R32 mk 5
Golf GTI mk 5
VW Passat 130d 4 motion
VW bora 150pd
Ford Mondeo Ghia X V6
Ford Focus zetec
Rover 214!!
PetrolDave
Post by PetrolDave » Sun Feb 12, 2012 6:54 pm
RS4414. wrote:My DRC has never failed or leaked at all...
Could be that the pressure is lower than it should be? That might explain the lack of leaks and the knocking.
brettRS4
Post by brettRS4 » Sun Feb 12, 2012 7:16 pm
I asked if they could check the pressure because if it was low that would make sense, but they said if it was low the valves would chatter at the rear of the car? It just seemed like they did not want to do it. I should hear back tomorrow but thee service up to now has been a bit iffy at best. Fingers crossed
PetrolDave
Post by PetrolDave » Sun Feb 12, 2012 7:31 pm
brett123 wrote:It just seemed like they did not want to do it ... the service up to now has been a bit iffy at best.
Sounds like time to get a second opinion to me.
brettRS4
Post by brettRS4 » Sun Feb 12, 2012 8:28 pm
If they don't come through tomorrow which dealer is best to try then? I'm up in the north east, Darlington
adsgreen
Post by adsgreen » Sun Feb 12, 2012 8:37 pm
brett123 wrote:Hi ads I've just tried it yes it does make a noise when engine is off. What could this mean? Tyne side Audi are trying goodwill on front shockers tomorrow anyway but what could this noise mean? Should it not make any noise wiggling the wheel?
Aha! Well worth trying this little investigation then.
Easier with a helper.
Pop the bonnet and remove the cover that's marked as a battery cover below the windscreen.
Look under here and you should see ecu number 2.
Below this is a large bolt - not sure but 12-13mm at least.
Get helper to wiggle the steering wheel.
This bolt is one of three that secure the steering rack in place.
very common on the whole a4 b7 platform for this bolt (or one of the others) to loosen.
If loose you'll see it move as the steering is moved - this is the knock you may be hearing.
Correct fix is to replace all three bolts as they are stretchy single use items and can't be retightened.
Torque is something like 40lb +90 degrees but will check.
This completely cured my problem - if you want I can take a picture tomorrow am to show the bolt.
adsgreen
Post by adsgreen » Sun Feb 12, 2012 8:47 pm
Here's the thread on my old issue including diagram
http://forum.rs246.com/viewtopic.php?f= ... ck#p411520
Bolts marked 2 are the top ones and the other I think is number 6
brettRS4
Post by brettRS4 » Sun Feb 12, 2012 10:03 pm
Thanks I will check it out tomorrow.
Users browsing this forum: Google Adsense [Bot] and 204 guests
