500hp
The 458 makes 560hp from 4.5 litres for 125hp/litre.
Assuming a B7 revs to 9000rpm the difference in piston speeds between a 458 and B7 would be 24.3m/s versus 27.8m/s....doesn't seem like much.
But the loads on the piston are proportional to acceleration and in the B7 would be greater by ~14% courtesy of the stroke.
I'm not sure why the B7 has such a long stroke?
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
Previous:
2007 B7 RS4 Saloon
1994 S2 Coupe
- PetrolDave
Just seen this on Audizine http://www.audizine.com/forum/showthrea ... -switching!
loads are ~ to aSR71 wrote:The 458 makes 560hp from 4.5 litres for 125hp/litre.
but a ~ v squared
so loads >30% higher
long stroke = more torque over time (rpm in this case)
hence 90% peak from 2500 to redline
Gardus@Supersprint
Flat plane crank does give a more balanced (so no need for counter weights) and high reving engine - key for NA power.
However, a long stroke implies small bore - this gives lower down torque but also smaller packaging. If you were to put short stroke engine in the front then it would need bigger bores for the same displacement dramamtically increasing the dimensions of the engine. With mid mounted this isn't so much of a problem as you can bin the rear seats but for front engined this hits the handling (in weight distribution and polar inertia).
As with most things, it's a compromise.
- RS4Molar
yes
absolutely correct
2007 Phantom Black DnA tuned (UK)stage 3 B7 RS4 saloon, hotchkis arb's, H&R springs, goodridge lines, ferodo DS 2500 pads, GMG cat back exhaust system, BMC panel filter.
2005 Grey B5 A4 2.0 TFSI sedan
2000 WRC WRX turbo-210/285 (kw/bhp) atw
Users browsing this forum: No registered users and 381 guests
