500hp
SR71
Post by SR71 » Wed Sep 01, 2010 9:20 am
The 458 makes 560hp from 4.5 litres for 125hp/litre.
Assuming a B7 revs to 9000rpm the difference in piston speeds between a 458 and B7 would be 24.3m/s versus 27.8m/s....doesn't seem like much.
But the loads on the piston are proportional to acceleration and in the B7 would be greater by ~14% courtesy of the stroke.
I'm not sure why the B7 has such a long stroke?
58 C6 RS6 Stage 2+
58 C6 A6 Allroad 2.7 TDi
Previous:
2000 B5 S4 MRC 550 Saloon
2007 B7 RS4 Saloon
1994 S2 Coupe
PetrolDave
Post by PetrolDave » Wed Sep 01, 2010 2:07 pm
ArthurPE
Post by ArthurPE » Wed Sep 01, 2010 3:31 pm
SR71 wrote:The 458 makes 560hp from 4.5 litres for 125hp/litre.
loads are ~ to a
but a ~ v squared
so loads >30% higher
long stroke = more torque over time (rpm in this case)
hence 90% peak from 2500 to redline
Gardus@Supersprint
Post by Gardus@Supersprint » Tue Sep 07, 2010 8:59 am
The 458 is flat crank too...
MoRS6+
Post by MoRS6+ » Tue Sep 07, 2010 9:09 am
Ah damn, only 485bhp but close to 500:
http://www.pistonheads.com/sales/1985510.htm
:lol:
RS4Molar
Post by RS4Molar » Tue Sep 07, 2010 11:02 am
MoRS6+ wrote:Ah damn, only 485bhp but close to 500:
:lol:
wouldn't beleive that at all!!!!!!!
2007 Phantom Black DnA tuned (UK)stage 3 B7 RS4 saloon, hotchkis arb's, H&R springs, goodridge lines, ferodo DS 2500 pads, GMG cat back exhaust system, BMC panel filter.
2005 Grey B5 A4 2.0 TFSI sedan
2000 WRC WRX turbo-210/285 (kw/bhp) atw
adsgreen
Post by adsgreen » Tue Sep 07, 2010 11:18 am
Flat plane crank does give a more balanced (so no need for counter weights) and high reving engine - key for NA power.
However, a long stroke implies small bore - this gives lower down torque but also smaller packaging. If you were to put short stroke engine in the front then it would need bigger bores for the same displacement dramamtically increasing the dimensions of the engine. With mid mounted this isn't so much of a problem as you can bin the rear seats but for front engined this hits the handling (in weight distribution and polar inertia).
As with most things, it's a compromise. :)
RS4Molar
yes
Post by RS4Molar » Tue Sep 07, 2010 11:22 am
absolutely correct :D
Users browsing this forum: QuRace and 101 guests
