Key Programming
MarkB
Post by MarkB » Thu Apr 03, 2008 3:22 pm
Mikey-S wrote:Good question! That's one for Ross Tech to answer. I'm not sure how that would work, but with Vag-Tacho you don't need any of the WSC, date or dealer codes. When using Vag com to code a key, the SKC is calculated using a combination of the date and the supplied codes. Vag Tacho reads the actual SKC code. Plus all of the B5 cars can be done using the 4 digit login, not the 7digit.
This all sounds incomplete to me so I'll be steering clear for now.
Mark
Mikey-S
Post by Mikey-S » Thu Apr 03, 2008 3:30 pm
If you have a B5 then you've nothing to worry about, it's only the later cars (2002 onwards I think) that will only accept the new style of dealer generated SKC. I've just sent Vag-Com a mail about using the Vag-TACHO supplied codes on a newer car, I'll keep you posted.
Look at it this way, if you own a B5 car, £25 as a one off payment is much better than paying the stealers between 1/2 and 1 hours labour everytime you need a key coding, or god knows how much if you needed to change an ECU/Cluster.
Mike
Mikey-S
Post by Mikey-S » Thu Apr 03, 2008 4:53 pm
"There is no need to use the 7 digit SKC dialog if you have the 4 digit PIN" - Straight from Vag-Com
MarkB
Post by MarkB » Fri Apr 04, 2008 7:48 am
Later B5 S4's don't have the 4 digit PIN.
Mark
R5YUG
Post by R5YUG » Fri Apr 04, 2008 8:16 am
That's interesting Mikey - I've got a version of VAG-TACHO (a few years old) but I haven't been able to read my SKC from my B5 RS4 as yet - tried over 20 times as the software can be a bit hit and miss in extracting the codes from clusters (Successfully read the code on a mates B5 Passat and MKIV Golf though).
What version of the software are you using out of interest and have you tried it on a facelift or post 2001 B5 Audi? TIA Guy
2012 Audi RS3 in Daytona Grey
2003 VW Golf IV R32 Turbo Deep Blue Pearl - "THE PROJECT"
1993 VW Golf Mk1 GTi Rivage Blue
1968 Karmann Ghia
Mikey-S
Post by Mikey-S » Fri Apr 04, 2008 9:47 am
I'm using version 2.2, I have found that if you let it connect to 'any' tacho then most of the options aren't available, but if you connect to 'VDO old' then there's no problem.
MarkB
Post by MarkB » Fri Apr 04, 2008 10:53 am
Mikey, what age S4's have you done it on?
Mark
Mikey-S
Post by Mikey-S » Fri Apr 04, 2008 12:20 pm
I've read the pin, coded keys and changed the mileage via Vag TACHO..... (only experimental) on both my 1998 S4 and 1999 1.8Tq. I have also logged in to the immob and coded keys with Vag COM using the Vag TACHO supplied pin. I have also done all of this on my 2001 Seat Leon tdi.
Return to “DTC / VCDS”
