This all sounds incomplete to me so I'll be steering clear for now.Mikey-S wrote:Good question! That's one for Ross Tech to answer. I'm not sure how that would work, but with Vag-Tacho you don't need any of the WSC, date or dealer codes. When using Vag com to code a key, the SKC is calculated using a combination of the date and the supplied codes. Vag Tacho reads the actual SKC code. Plus all of the B5 cars can be done using the 4 digit login, not the 7digit.
Key Programming
Mark
If you have a B5 then you've nothing to worry about, it's only the later cars (2002 onwards I think) that will only accept the new style of dealer generated SKC. I've just sent Vag-Com a mail about using the Vag-TACHO supplied codes on a newer car, I'll keep you posted.
Look at it this way, if you own a B5 car, £25 as a one off payment is much better than paying the stealers between 1/2 and 1 hours labour everytime you need a key coding, or god knows how much if you needed to change an ECU/Cluster.
Mike
Mike
That's interesting Mikey - I've got a version of VAG-TACHO (a few years old) but I haven't been able to read my SKC from my B5 RS4 as yet - tried over 20 times as the software can be a bit hit and miss in extracting the codes from clusters (Successfully read the code on a mates B5 Passat and MKIV Golf though).Mikey-S wrote:Good question! That's one for Ross Tech to answer. I'm not sure how that would work, but with Vag-Tacho you don't need any of the WSC, date or dealer codes. When using Vag com to code a key, the SKC is calculated using a combination of the date and the supplied codes. Vag Tacho reads the actual SKC code. Plus all of the B5 cars can be done using the 4 digit login, not the 7digit.
What version of the software are you using out of interest and have you tried it on a facelift or post 2001 B5 Audi? TIA Guy
2012 Audi RS3 in Daytona Grey
2003 VW Golf IV R32 Turbo Deep Blue Pearl - "THE PROJECT"
1993 VW Golf Mk1 GTi Rivage Blue
1968 Karmann Ghia
1968 Karmann Ghia
Users browsing this forum: Google Adsense [Bot] and 59 guests
