Fan assisted side mount intercoolers
BRETTCOLLINS
Post by BRETTCOLLINS » Tue Feb 05, 2008 9:41 am
fit a APR by-pipe the tap in to water jets, one at each side ( intercooler ends) of the by-pipe. I am running 7mm jets with 50/50 mix. made so much difference when the car was running RS4 IC's. Still makes a differences with the FMIC, but IMO it is must with side mount units..
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
MarkB
Post by MarkB » Tue Feb 05, 2008 10:06 am
BRETTCOLLINS wrote: 50/50 mix.
Where can the meth be bought from?
Mark
BRETTCOLLINS
Post by BRETTCOLLINS » Tue Feb 05, 2008 10:37 am
Good Model shops, ones that sell planes
MING BLUE AUDI S4
Car is on Lock down
MarkB
Post by MarkB » Tue Feb 05, 2008 10:40 am
What sort of amounts get used and cost? MPG :)
Mark
BRETTCOLLINS
Post by BRETTCOLLINS » Tue Feb 05, 2008 5:44 pm
No idea mate. Got 10 litres about a year ago. Still using it... LOL
MING BLUE AUDI S4
Car is on Lock down
pistonart
Post by pistonart » Wed Feb 06, 2008 1:47 am
Problem with water injection is as someone pointed out, if you do not check it regually enough, your likely to run out. Some tune with water off, but then you dont see the full benefit of water injection.
Anyone tried a charge cooler?
V Mounts are a very good option, front mounts although cool your charge, cause the rads to get hotter as you are obstructing the air flow, and if you want more power you will get higher running temps. Anyone tried a V mount?
You can get meths here.
http://www.oil-shop-uk.co.uk/acatalog/V ... _fuel.html
Be very careful playing with meths,
It burns clear, so you cant see if alight, and if mixing it needs to be reasonable well measured out as different mixes can make big differences in tuning AF's.
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Feb 06, 2008 10:30 am
My car was tuned with the water injection running. Have sensor in bottle to tell me when the water is low and have a wide band AFR gauge in the car too.
MING BLUE AUDI S4
Car is on Lock down
Hutch
Post by Hutch » Wed Feb 06, 2008 3:29 pm
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Feb 06, 2008 3:35 pm
don't think much of there site LOL
MING BLUE AUDI S4
Car is on Lock down
Hutch
Post by Hutch » Wed Feb 06, 2008 4:58 pm
Lucky it's their meths powering your car then and not the site.
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Feb 06, 2008 5:11 pm
something Like that.. LOL nice and near to me too.. Am changing the jets in my car to 8mm from 7mm this weekend
MING BLUE AUDI S4
Car is on Lock down
Hutch
Post by Hutch » Wed Feb 06, 2008 5:21 pm
Don't mess around get the 1.0mm in. :nodder:
BRETTCOLLINS
Post by BRETTCOLLINS » Wed Feb 06, 2008 5:24 pm
what and then take the engine out and fix it again like you :bowdown:
MING BLUE AUDI S4
Car is on Lock down
f1
Post by f1 » Thu Feb 14, 2008 5:47 pm
Richard at aquamist has developed a flow gauge that not only monitors the amount of water being injected but also has a float for the water/methanol bottle that cuts the water spray when it gets low and informs the driver via the gauge.
I do sell them but dont want to upset the mods or anyone on here although i will be taking advertising up on here soon!
mattysupra
Post by mattysupra » Sat Feb 16, 2008 3:32 pm
i had fans fitted to the back of my intercooler on my drag car. only used them after a run and just before a run. If you have them on while your driving it will actually make the car slower due to the extra current draw! I also used nitrous to cool the intercooler but again only just before the lights go green, its a waste of nos to use it all the time. We used the waste of the purge valve that you should blow out anyway before using it. Otherwise the first second or so of nitrous going into the engine is a gas and not liquid which is bad.
