Wipers
- mikeyquattro
- Top Gear
RE: Re: wipers
Nut inside the ECU box. Unplug the ECu and then you should be able to see it
Tomorrow is another day
RE: Re: wipers
Yep - managed to find it thanks.
RE: Re: wipers
Great...turning into a right old saga this one....
ECU now removed from box. BUT, there's insufficient slack in the wiring to pull the ECU box forward by more than a few mm - insufficient to allow me to remove the wiper linkage.
There are 5 wiring connectors that need to be removed from the back of the box ( that fit into a recessed hole underneath the ECU box ). It's not obvious how to remove these connectors and very little room to do it either ( no room for fingers ). Is it just a case of yanking with a pair of pliers ? Are there tangs that need to be opened / pressed in ?
There's been no mention of having to do this on any of the previous threads on this subject
perhaps my wiring is shorter than anyone elses ! That'd be just my luck..
Starting to get fed up with this...I looked into getting this done at a garage or stealerships earlier by claiming on WarrantyDirect....guess what - the wiper motor is covered, not the linkage. Typical.
TIA
Rick.
TIA
Rick.
- mikeyquattro
- Top Gear
Users browsing this forum: No registered users and 70 guests
