Wipers
2.7 V6 30v biturbo - 380 bhp
mikeyquattro
RE: Re: wipers
Post by mikeyquattro » Sun Sep 28, 2008 3:10 pm
Nut inside the ECU box. Unplug the ECu and then you should be able to see it
Tomorrow is another day
rickoshea
RE: Re: wipers
Post by rickoshea » Sun Sep 28, 2008 7:45 pm
Yep - managed to find it thanks.
rickoshea
RE: Re: wipers
Post by rickoshea » Mon Sep 29, 2008 8:31 pm
Great...turning into a right old saga this one....
ECU now removed from box. BUT, there's insufficient slack in the wiring to pull the ECU box forward by more than a few mm - insufficient to allow me to remove the wiper linkage.
There are 5 wiring connectors that need to be removed from the back of the box ( that fit into a recessed hole underneath the ECU box ). It's not obvious how to remove these connectors and very little room to do it either ( no room for fingers ). Is it just a case of yanking with a pair of pliers ? Are there tangs that need to be opened / pressed in ?
There's been no mention of having to do this on any of the previous threads on this subject :( perhaps my wiring is shorter than anyone elses ! That'd be just my luck..
Starting to get fed up with this...I looked into getting this done at a garage or stealerships earlier by claiming on WarrantyDirect....guess what - the wiper motor is covered, not the linkage. Typical.
TIA
Rick.
Jarv
Post by Jarv » Mon Sep 29, 2008 9:31 pm
They should just pull out.
Mike
Q7
mikeyquattro
Post by mikeyquattro » Mon Sep 29, 2008 9:39 pm
IIRC you should slide a locking mech. out, then they pull out
rickoshea
Post by rickoshea » Tue Sep 30, 2008 12:16 am
There's a sliding mech on the ECU connectors which allows the ECU to be removed, however I don't recall seeing a sliding mech for the 5 square plugs.
Will have to strip it all down again and take another look.....
Users browsing this forum: No registered users and 208 guests
