RS6+ Discs V RS4 B7 Discs
viperbl
Re: RE: Re: RE: Re: RE: RS6+ Discs V RS4 B7 Discs
Post by viperbl » Mon May 14, 2007 10:48 am
S4TAN wrote:
do the holes line up either side of the disc to allow drilling?
Yes they do ... but a drill isn't required; just a small flat-blade screwdriver poked through each hole pushes the plugs out ...
I tried, mine where ROCK solid!!!!! :shock:
Even with a drill it was hard work!!! must remember and not leave them so long next time!
RS4 B5 Saloon8) with 750+ bhp :D
Ads4
RE: Re: RE: Re: RE: Re: RE: RS6+ Discs V RS4 B7 Discs
Post by Ads4 » Mon May 14, 2007 10:55 am
What sort of time scale do you recommend? Every 5k with the oil-change?
Adam.
MRC B5 S4 Avant.
S4TAN
Post by S4TAN » Mon May 14, 2007 10:56 am
Mine have been rock solid plugs too ... but a judicious "twist" action with the flat-blade penetrates the plug and allows a push-through ... i guess regular maintenance is the answer.
Viper; maybe you need to get down the gym more often and pump some iron ... :lol:
Deus ex machina
viperbl
Re: RE: Re: RE: Re: RE: Re: RE: RS6+ Discs V RS4 B7 Discs
Post by viperbl » Mon May 14, 2007 11:00 am
All depends on driving ... since I only got 3k out my pads, so that would not work for me!!!
@S4tan, yeah, I hear what your saying ... I was just trying to push them as opposed to geting purchase and breaking its seat as such ...
Also, after hearing what David's said about the fact they are cast and not drilled, I am thinking drilling is not a good idea, as its going to hit the sides and maybe cause problems later ...
DavidT
RE: Re: RE: Re: RE: Re: RE: Re: RE: RS6+ Discs V RS4 B7 Disc
Post by DavidT » Mon May 14, 2007 11:03 am
LOL, just do them when they start to look blocked.
What are other peoples experiences with them ?
S4TAN
Post by S4TAN » Mon May 14, 2007 11:04 am
For sure ... i wouldn't put a drill anywhere near my discs (but that's because i am seriously cack-handed with power-tools! :lol: )
Deus ex machina
derdle
Post by derdle » Mon May 14, 2007 11:12 am
I use a low speed battery drill and "blunted" drill bit. Have to attack the discs from both sides though - Don't think you can drill through.
I suppose the easiest way would be to use a flexible drill/drive shaft?
Paul
S4TAN
Post by S4TAN » Mon May 14, 2007 11:18 am
You definitely CAN with the B7 RS4 discs - the holes in both discs are aligned, so you only have to do it from one side; place small flat-blade tip in hole on dust plug, twist and push through ... repeat all the way round the disc until bored ... (forgive the pun) ... you can feel the blade go through and exit on the other disc ... a big pile of dust will appear on the floor as you go round the disc ...
Deus ex machina
DavidT
Post by DavidT » Mon May 14, 2007 11:20 am
Back on topic then, thats a big practical difference between RS6+ & RS4 discs - the holes line up so you can clear them easily?
S4TAN
Post by S4TAN » Mon May 14, 2007 11:24 am
Well, they definitely line up on the B7 RS4 discs that i've got .... and are cleared easily from one side .... maybe i'm just lucky?
Deus ex machina
DavidT
Post by DavidT » Mon May 14, 2007 11:38 am
That is enough to make me choose them over RS6+ ones on its own.
Floating is also better than solid too.
viperbl
Post by viperbl » Mon May 14, 2007 11:43 am
My initial thinking was to go RS4 B7 disks first, because no moficiation needed and it was cheaper. My thoughts where, when those discs come to the end of their life, I can move to RS6+ if needed, but, to be honest, I recon I will get another set of B7's, as they do the job, WELL!! and I used to go through discs like hot dinners, so, if they can hold up to my driving, they are good!
Ads4
Post by Ads4 » Mon May 14, 2007 11:46 am
So maintenance-wise the B7 discs are the ones to go for. On e-bay they're £475 for the fronts, compared to £415 for the RS6 so not a lot in it really. As you say David, I think that having the discs alligned makes it a simpler choice. Cheers guys :thumbs:
Adam.
MRC B5 S4 Avant.
Ads4
Post by Ads4 » Mon May 14, 2007 11:48 am
Not surprised, having seen some of your videos... :wink:
Adam.
MRC B5 S4 Avant.
MCB
Post by MCB » Tue May 15, 2007 8:53 am
Anyone know if the RS4 ones have curved vanes?
S4B5 Avant
