Combat Turbo Lag!
viperbl
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Combat Turbo
Post by viperbl » Tue Dec 05, 2006 10:07 pm
flashyg wrote:So how good is your fly and clutch compared to the stock feel?
Are u getting better spool up etc.
Is it the best on the market?
See,
http://www.rs246.com/index.php?name=PNp ... ic&t=57416
Its hard to say if it spools up quicker, I would say yes, but there is not much in it, you would only notice it if you jumped from one setup to the other I feel.
As I said, main difference is how nice the bite is, no slip at all, and with the duel mass flywheel there is some give between the plates, now their is not so it does feel more direct.
If the mrs does not like 'jerky' gear changes don't get! as 1st / 2nd can be.[/url]
DavidT
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Combat Turbo Lag!
Post by DavidT » Tue Dec 05, 2006 10:21 pm
viperbl wrote:
DavidT wrote:Lightweight flywheel fixes that Simon :thumbs:
Have to disagree David, when I got my single mass lightweight flywheel I expected it to help, but you know what, it made little difference!! Maybe a little better, but not a lot to be honest ... :(
RPM dies much, much faster with mine, no need to debate that ;)
Perhaps its in your mapping. Do you have the over-run fuel cut off enabled for example ?
viperbl
Post by viperbl » Tue Dec 05, 2006 10:27 pm
Really??!? Right, dam, another thing to look into!!! (Where are these light evenings when you need them!!)
I did not realise you had a lightweight flywheel, and I just assumed that mine was the norm, apologies.
Well, its an MRC map, and I have no idea how to, or check that I have the over-run fuel cut off enabled ...
This is good news, because I was a little disappointed when it did not make a difference. I mean, I did not expect it to act like an F1 engine, but I certainly expected a noticeable difference...
DavidT
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Combat Turbo Lag
Post by DavidT » Tue Dec 05, 2006 10:37 pm
I've got an RS4 clutch and Tanoga lightweight flywheel.
If the over-run fuel cut off is enabled (like a standard car) the instant mpg reading on the DIS will go to --- when you lift off the gas over 1k ish rpm. If this feature is disabled, the DIS will only get to 100mpg or so.
The way the engine revs and dies is one of the first things people notice. 6+ kg less to turn I guess.
We're way off topic mind :)
viperbl
Post by viperbl » Tue Dec 05, 2006 10:42 pm
DavidT wrote:We're way off topic mind :)
Lol! Yes, Shall we continue this at
http://www.rs246.com/index.php?name=PNp ... ic&t=57416 ? :lol:
s4woody
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Combat T
Post by s4woody » Wed Dec 06, 2006 1:48 pm
so is it a good idea to disable this feature and will it help the revs drop quicker..my dis reads --- so mine must enabled..
GARTH ROAD MOT CENTRE LTD
020 83353032
GrahamS4
Post by GrahamS4 » Wed Dec 06, 2006 2:09 pm
Going to have to go out in the car to see if i have this......is it a standard MRC map feature?
DavidT
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Comb
Post by DavidT » Wed Dec 06, 2006 3:02 pm
s4woody wrote:so is it a good idea to disable this feature and will it help the revs drop quicker..my dis reads --- so mine must enabled..
Confusing, but it should be enabled, as per the factory settings:
Enabled = dis goes to --- on the overun - stock setting
Disabled= dis only goes to 100mpg or so on the overrun - tuner setting.
Very noticeable difference, car is smooher to drive with the feature disabled because the throttle is never 100% closed.
I could be talking arse about how the revs fall between gears with it enabled or disabled, it was just a quick guess when viperbl said his LWFW did not make any difference to how 'light' the engine felt. I noticed a big difference with the LWFW.
Dippy
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE:
Post by Dippy » Wed Dec 06, 2006 3:12 pm
While we're on the subject David, does your LWFW have any significant effect on noise and urban/traffic "driveability"?
2001 Silver S4 Avant
DavidT
Post by DavidT » Wed Dec 06, 2006 3:22 pm
GrahamS4 wrote:Going to have to go out in the car to see if i have this......is it a standard MRC map feature?
No, they leave it enabled usually, but being a very fussy customer, I've had a few settings changed to help with driveability, although mine is enabled again now.
DavidT
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re:
Post by DavidT » Wed Dec 06, 2006 3:26 pm
Dippy wrote:While we're on the subject David, does your LWFW have any significant effect on noise and urban/traffic "driveability"?
I hated it for about the first week. Between 1 & 2k rpm on a high load in any gear (some worse than others) makes the gears chatter badly. I was annoyed with myself for spending a wedge on something that made the car worse :(
Since then I've got used to driving around it a little and I never notice it now, ever. When other people drive the car I remember it though :)
viperbl
It works
Post by viperbl » Wed Dec 06, 2006 8:40 pm
I went out and tried changing gear with the right foot firmly planted to the floor the whole time.
It goes into gear easy, no issues, and then the clutch bites, no slip at all so as you can imagine quite a thump as everything sorts itself out.
Now the important part, as should be the turbo's are still spooled up, my boost gauge is showing around 1.2bar at redline, when I put the clutch in this drops off (although I assume this is pressure, at the turbos are still spinning). Once the gear is engage it immediately jumps to around 1.4 ish bar, which I would expect to get to eventually, but its more or less instant!
All happy now! Quick and simple anti lag system for my hill climb!
MarkB
RE: It works
Post by MarkB » Wed Dec 06, 2006 8:56 pm
Just don't do it too much, unless you like have the car in bits alot ;)
Mark
viperbl
Re: RE: It works
Post by viperbl » Wed Dec 06, 2006 9:04 pm
MarkB wrote:Just don't do it too much, unless you like have the car in bits alot ;)
:lol: Agreed
ZeroK66
RE: Re: RE: It works
Post by ZeroK66 » Wed Dec 06, 2006 10:44 pm
Mihnea seems to think that Tubular manifolds help speed up spooling... this is his experience when mapping with them? I would have thought the opposite, but there you go.
Users browsing this forum: No registered users and 70 guests
