To short shift or not to short shift that is the question!!!
RE: Re: RE: To short shift or not to short shift that is the
Mine was cheap as chips... so we'll see how good it is if I ever get around to fitting it!
Mark
I had to say that so as not to offend any of the more sensitive members....
Deus ex machina
So if I get my cheapo one to work well...??
Mark
Well you can congratulate yourself then...!
Deus ex machina
Re: RE: Re: RE: To short shift or not to short shift that is
Mark - you will - not first time, but it's not difficultMarkB wrote:So if I get my cheapo one to work well...??
I hope this doesnt offend anyone who spent a lot on theirs
Clive
RE: Re: RE: Re: RE: To short shift or not to short shift tha
Nope! Mine cost squillions of pounds and I am NOT offended Clive
Deus ex machina
Phew!
Clive
- shineydave
mine cost bugger all, i of course, am also not offended.
- shineydave
works a treat, exactly like the standard shift but the leaver is shorter and the throw reduced. still has the compliant feel that comes as standard. because the shortshifter kits come with solid nylon bushings instead of rubber the feel of the kit is, in my opinion, more accurate but the downside is it doesn't have that tactile feel of the modded standard shifter
Re: unsure
The DTS clamps your transmission housing in place underneath the car and stops any movement of it when accelerating/decelerating etc. especially in the direction of travel. So when you have an s/s too it makes for really tight and precise gear shifts with no "slop".....trevs4 wrote:s4tan what do you mean by If you haven't got a DTS already get one of them too - works brilliantly in conjunction with a shortshift stick...
Does that explain it...?
Deus ex machina
RE: Re: unsure
@satan dnt u mean stops the twisting effect in the gearbox..not really sure that the direction of travel plays any part..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
RE: Re: unsure
nope, i don't mean that: When you accelerate forward the transmission housing has intertia, and when you decelerate the transmission housing has momentum, so you can sometimes feel it moving backwards and forwards when accelerating/decelerating.....the DTS stops this (and can stop your OEM snub mount from getting fvcked!)
Deus ex machina
