S4 key recoding
General Forum for Warranty, Dealers, Servicing, Insurance, Breakdown, etc
fletchie55
RE: Re: RE: S4 key recoding
Post by fletchie55 » Fri Sep 15, 2006 10:14 am
yeah, basically the metal part that holds the blade into the key snapped.
MarkB
Post by MarkB » Fri Sep 15, 2006 10:17 am
as said before then, just get a new blade off ebay £2.99, get it cut for about £10, knock the pin out replace with new blade, re-insert pin. Job Done :)
Mark
MCB
Post by MCB » Fri Sep 15, 2006 3:55 pm
I think there is possibly a misunderstanding developing here, if I understand correctly:
1. fletchie55 has a damaged switchblade key fob, that several of us have been refering to as a transponderd.
2. He has aquired a new switchblade key fob and wants to fit his old undamaged key (Switchblade / transponder is damaged) to this then reprogramme it to the car.
Hence my post:
An Audi Stealer will charge you approx £50 (No less) to sort this out for you or alternatively you could try:
1. Have a new blank key cut and have them fit it to your new - not working transponder.
2. Jury rig your old key together - tape or whatever you can use.
Then try the instructions in my post.
S4B5 Avant
MCB
Post by MCB » Fri Sep 15, 2006 3:56 pm
Transpondered... new name for it... I think I am transpondered by this thread!
S4B5 Avant
MarkB
Re: RE: Re: RE: S4 key recoding
Post by MarkB » Fri Sep 15, 2006 4:10 pm
MCB wrote:I think there is possibly a misunderstanding developing here, if I understand correctly:
Hence my post:
Yes he did say that, but has since said that it was just the metal part that broke so that is all that needs replacing. If it was only the blade, not the part the blade plugs in to. If it is indead the part it plugs into then it's a trip to the dealers for the transponder recode and follow the instructions on here to sync the remote locking buttons
Mark
MCB
RE: Re: RE: Re: RE: S4 key recoding
Post by MCB » Fri Sep 15, 2006 8:01 pm
Yep managed to work that out, although still transpondered, going to the pub for a new battery!
S4B5 Avant
tdiquattro
Post by tdiquattro » Sun Sep 17, 2006 7:24 pm
Hi Chaps,
I have some pics of the key sections, will post tomorow,
It is quite easy to move the blade and "transponder" from one front part of the key to the other. There is a small screw under the audi symbol to take the front part of the key to bits. If you want the shiny new front part of the key, dig out the two transponders (small fragile glass tubes) and swap them over.
btw , a transponder is a passive aerial and transmitter that is excited by RF energy and transmits by converting the Radio Freq energy to D/C power!
Nige.
Nige'
2000 silver S4 Saloon
tdiquattro
Post by tdiquattro » Mon Sep 18, 2006 3:03 pm
here are some pics of a 2000 key and later key, the transponder is the small green cylinder...
[img]modules/pnCPG/Coppermine/albums/userpics/10567/key2.JPG[/img]
[img]modules/pnCPG/Coppermine/albums/userpics/10567/key1.jpg[/img]
[img]modules/pnCPG/Coppermine/albums/userpics/10567/rs246_norm_key3.JPG[/img]
Nige'
Return to “Audi S and RS Ownership”
Users browsing this forum: No registered users and 26 guests
