S4 key recoding
fletchie55
RE: Re: RE: S4 key recoding
yeah, basically the metal part that holds the blade into the key snapped.
as said before then, just get a new blade off ebay £2.99, get it cut for about £10, knock the pin out replace with new blade, re-insert pin. Job Done
Mark
I think there is possibly a misunderstanding developing here, if I understand correctly:
1. fletchie55 has a damaged switchblade key fob, that several of us have been refering to as a transponderd.
2. He has aquired a new switchblade key fob and wants to fit his old undamaged key (Switchblade / transponder is damaged) to this then reprogramme it to the car.
Hence my post:
An Audi Stealer will charge you approx £50 (No less) to sort this out for you or alternatively you could try:
1. Have a new blank key cut and have them fit it to your new - not working transponder.
2. Jury rig your old key together - tape or whatever you can use.
Then try the instructions in my post.
Hence my post:
S4B5 Avant
Transpondered... new name for it... I think I am transpondered by this thread!
S4B5 Avant
Re: RE: Re: RE: S4 key recoding
Yes he did say that, but has since said that it was just the metal part that broke so that is all that needs replacing. If it was only the blade, not the part the blade plugs in to. If it is indead the part it plugs into then it's a trip to the dealers for the transponder recode and follow the instructions on here to sync the remote locking buttonsMCB wrote:I think there is possibly a misunderstanding developing here, if I understand correctly:
Hence my post:
Mark
RE: Re: RE: Re: RE: S4 key recoding
Yep managed to work that out, although still transpondered, going to the pub for a new battery!
S4B5 Avant
- tdiquattro
Hi Chaps,
I have some pics of the key sections, will post tomorow,
It is quite easy to move the blade and "transponder" from one front part of the key to the other. There is a small screw under the audi symbol to take the front part of the key to bits. If you want the shiny new front part of the key, dig out the two transponders (small fragile glass tubes) and swap them over.
btw , a transponder is a passive aerial and transmitter that is excited by RF energy and transmits by converting the Radio Freq energy to D/C power!
Nige.
Nige.
Nige'
2000 silver S4 Saloon
- tdiquattro
here are some pics of a 2000 key and later key, the transponder is the small green cylinder...
[img]modules/pnCPG/Coppermine/albums/userpics/10567/key2.JPG[/img]
[img]modules/pnCPG/Coppermine/albums/userpics/10567/key1.jpg[/img]
[img]modules/pnCPG/Coppermine/albums/userpics/10567/rs246_norm_key3.JPG[/img]
Nige'
Users browsing this forum: No registered users and 10 guests
