RS4/RS6 Hybrid conversion 99% done....
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
KayGee
RE: Re: RE: Re: RE: Re: RE: RS4/RS6 Hybrid conversion 99% do
Post by KayGee » Thu Aug 03, 2006 7:30 pm
FlashyG,
I meant it was a tangent to this thread, since its supposed to be about Robs hybrid beast.
No problem and glad to help.
flashyg
Post by flashyg » Thu Aug 03, 2006 7:37 pm
of Course... Thanks KayGee.
Come on then Tartan Rob lets here more about your Beast.
dummi
Post by dummi » Thu Aug 03, 2006 9:16 pm
flashyg you sound like your tearing your hair out right now, why not start a thready on issues your having with your car and the forum will help you work through it, you have mentioned there is something wrong with your car but not symptoms maybe we can suggest possible causes from our own problems
sorry Tartan Rob for interuptions to this thread i'm really quite excited to see your rs4/rs6 s4 as its what i'm hoping for mine when its complete like a little insight into the future :wink:
MarkB
Re: RS4/RS6 Hybrid conversion 99% done....
Post by MarkB » Thu Jan 31, 2008 4:29 pm
Tartan_Rob wrote:I'm not long back from MRC where Doug kindly fitted RS4 downpipes...
Mihnea did his thing with the laptop again and after 2/2.5 hours we had made little progress but plenty of head scratching. In a bid to resolve the surging he disabled lambda correction (Mihnea - jump in when I start talking poo) :? . The car turned into a complete animal with the manners of the queen :twisted: . What a difference, she is pulling good timing, running smoothly, no surging and no bad off throttle jumping.....I'm taking the car for a gas analysis in August to see how she'll cope with an MoT without Lambda, that gives Mihnea time to research the Lambda issue.
As for performance, I have not really done any measurements but before I got there, she ran approx 140 up the hill...remember that was before Lambda turned off and car is running better now.....FATs time was very approx 3.5sec....not bad for a 1.9Tdi :D
I'll try and post some times this weekend....
Hi Rob
Do you remember what the full spec of the engine was?
Airbox =
Maf =
Y-Pipe =
Turbo inlets =
Turbo spec =
Intercoolers = RS4
Inlet manifold =
Injectors =
Fuel Pump =
Heads =
Compression =
Exhaust manifolds =
Downpipes = Gutted pre cat RS4
Exhaust =
Mark
saf
RE: Re: RS4/RS6 Hybrid conversion 99% done....
Post by saf » Thu Jan 31, 2008 5:18 pm
Im building a similar car to that of Tartan Robs. Hopefully he will correct me if Im wrong.
If I remember correctly his car was running
RS4 IC's.
K04 hybrids with the RS6 compressor wheel. (Ill be running an upgraded version of those wheels so can run more boost.
Lowered Compression
RS4 Clutch
S4 modded Air box
RS4 turbo inlets
S4 Y pipe
RS4 MAF
Gutted Precats RS4 downpipes , Not sure about exhaust but I cant remember it being an RS4 Milltek. I think it was standard Milltek.
s4woody
Post by s4woody » Thu Jan 31, 2008 5:28 pm
ive driven his old car and its a flyer..
GARTH ROAD MOT CENTRE LTD
020 83353032
rikrose
Post by rikrose » Thu Jan 31, 2008 6:19 pm
I've actually thought about trying something a little different. I'm loving having my turbos ready by 1800 rpm. I'm giving serious thought to working towards having K04/K16 or K04/K26 with some hot-side work done that will lower when the boost is available, with a sacrifice on how much boost is available, so that the car continues to drive without massive lumps in the power band. I quite like that, and having been in jeffw's rs4, I got to experience a car that actually does that. One day.. one day, I'd love that sort of power wit hthe same sort of driveability. I would sacrifice top end for that. I have a partial list of what was done, but parts are secret to MTM.
Goodwood green RS4, previously owned by jeffw
MarkB
Re: RE: Re: RS4/RS6 Hybrid conversion 99% done....
Post by MarkB » Thu Jan 31, 2008 7:11 pm
saf wrote:Im building a similar car to that of Tartan Robs. Hopefully he will correct me if Im wrong.
RS4 IC's.
Lowered Compression
RS4 Clutch
S4 modded Air box
RS4 turbo inlets
S4 Y pipe
RS4 MAF
Did Rob have the lowered compression and RS4 maf?
Mark
rikrose
RE: Re: RE: Re: RS4/RS6 Hybrid conversion 99% done....
Post by rikrose » Thu Jan 31, 2008 7:12 pm
Isn't dropping the compression necessary at those sort of boost levels, to avoid having a 2.7 litre grenade?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Thu Jan 31, 2008 8:21 pm
Where is robs old car these days then?
http://www.MRCtuning.com
Blue_Thunder
Post by Blue_Thunder » Thu Jan 31, 2008 8:33 pm
Someone off here bought it. And to think I was this close (pinches fingers together and cries a little) to buying it before I bought the money pit!
saf
Post by saf » Thu Jan 31, 2008 8:56 pm
Yes it did definitely have dropped compression, and a Milltek Dual catback (S4 one). Not sure about the RS4 MAF.
JonnyX
Re: RE: Re: RE: Re: RS4/RS6 Hybrid conversion 99% done....
Post by JonnyX » Fri Feb 01, 2008 10:18 am
saf wrote:Yes it did definitely have dropped compression, and a Milltek Dual catback (S4 one). Not sure about the RS4 MAF.
Similar to my car then. I'm running:
RS4 Dowpipes (gutted pre-cats)
Milltek Dual
RS4 clutch
RS4 IC's
RS4 MAF, Airbox, Y pipe
MRC injectors
MRC intake pipes
Ported and TIG welded stock manifolds.
Lowered CR.
K04's with P&P inlet and hotside.
Not running great at the moment though :-(. Off to MRC tomorrow to hopefully get
it sorted.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
MarkB
Post by MarkB » Fri Feb 01, 2008 10:22 am
JonnyX wrote: Not running great at the moment though :-(. Off to MRC tomorrow to hopefully get
it sorted.
Whats up with it Jon?
How much has the CR been lowered by and what method?
Mark
Users browsing this forum: No registered users and 71 guests
