I meant it was a tangent to this thread, since its supposed to be about Robs hybrid beast.
No problem and glad to help.
Hi RobTartan_Rob wrote:I'm not long back from MRC where Doug kindly fitted RS4 downpipes...
Mihnea did his thing with the laptop again and after 2/2.5 hours we had made little progress but plenty of head scratching. In a bid to resolve the surging he disabled lambda correction (Mihnea - jump in when I start talking poo). The car turned into a complete animal with the manners of the queen
. What a difference, she is pulling good timing, running smoothly, no surging and no bad off throttle jumping.....I'm taking the car for a gas analysis in August to see how she'll cope with an MoT without Lambda, that gives Mihnea time to research the Lambda issue.
As for performance, I have not really done any measurements but before I got there, she ran approx 140 up the hill...remember that was before Lambda turned off and car is running better now.....FATs time was very approx 3.5sec....not bad for a 1.9Tdi![]()
I'll try and post some times this weekend....
Did Rob have the lowered compression and RS4 maf?saf wrote:Im building a similar car to that of Tartan Robs. Hopefully he will correct me if Im wrong.
If I remember correctly his car was running
RS4 IC's.
K04 hybrids with the RS6 compressor wheel. (Ill be running an upgraded version of those wheels so can run more boost.
Lowered Compression
RS4 Clutch
S4 modded Air box
RS4 turbo inlets
S4 Y pipe
RS4 MAF
Gutted Precats RS4 downpipes , Not sure about exhaust but I cant remember it being an RS4 Milltek. I think it was standard Milltek.
Similar to my car then. I'm running:saf wrote:Yes it did definitely have dropped compression, and a Milltek Dual catback (S4 one). Not sure about the RS4 MAF.
Whats up with it Jon?JonnyX wrote: Not running great at the moment though. Off to MRC tomorrow to hopefully get
it sorted.
