New owner needing somexadvice
TOPMAN
Re: New owner needing somexadvice
Post by TOPMAN » Thu May 08, 2025 8:43 am
From my own notes:
Suction Jet Pump Problem.
Diagram of inlet manifold and SJP (various needed)
https://www.lllparts.co.uk/catalogs/aud ... 133/133041
Diagram of inlet manifold vacuum pipe work including turbo pressure pipes (O rings needed).
https://www.lllparts.co.uk/catalogs/aud ... 133/133040
N90832501 (O ring)
Diagram of cooling pipes under inlet manifold
https://www.lllparts.co.uk/catalogs/aud ... 121/121063
Diagram of inlet manifold gaskets (various needed)
https://www.lllparts.co.uk/catalogs/aud ... 133/133020
Diagram showing fuel rail and injectors (O-rings needed)
https://www.lllparts.co.uk/catalogs/aud ... 133/133030
Diagram of air-box and MAF seals
https://www.lllparts.co.uk/catalogs/aud ... 133/133010
Diagram of rocker covers
https://www.lllparts.co.uk/catalogs/aud ... 103/103060
I cross-referenced the pump from many pictures to a Pierburg 7.02074.75.0 from the C6 RS6 and some other newer Audi models. I can confirm it works perfectly.
I contacted Bosch about the IAT and they gave me part number 0 280 130 060 and I can confirm this is fine also, even though different.
Buy whichever SJP you like, I bought Stark brand, but they are all pretty much the same.
The O rings for the turbo pressure return pipes can be found in the diagram above and you can buy those from LLL Parts for a few quid a pair.
The rest of the parts you can buy from Auto-Doc.
When re-torquing the manifold I recommend using an accurate known wrench and torquing to 15Nm not 10 as suggested as these manifold seem to rattle themselves a bit loose.
Regards
Craig Barlow
P.S. I don't come here daily, if you need a quick response contact me on FB or FB messenger :-) GOOD LUCK
Users browsing this forum: 111marc111, asgor, ChrisA, Google [Bot], Shoppinit and 100 guests
