gearbox tcu
111marc111
- 1st Gear
Re: gearbox tcu
https://www.ecutesting.com/product-cata ... nsmission/
Try this website. Heard good things about them and subsequently I'm sending my abs unit off to them for repair Monday.
The website suggests the can supply a new TCU, I suspect refurbed, but they can also rebuild yours or at least diagnose it and prove it to be ok.
Might be worth a shot.
Re: gearbox tcu
mornung ,all codes for the tcu 18223 pressure control solenoid"A" control circuit high, status passive sporadic
Re: gearbox tcu
Ok. Not F125 related. Based on the info supplied I’d say it’s worth a punt to replace the TCU.
Re: gearbox tcu
Thanks all , will let the out come be known.
Re: gearbox tcu
I had the same issue, water leak through the bonnet cable soaked the TCU and was getting the same codes again an again but only if I turned ignition on an left it. Took a punt on a TCU and problem solved.
Re: gearbox tcu
I used ECU testing to repair my ABS control module, can also recommend them.
They charge a nominal fee to test your module to see if there are any faults before the full fee to repair any faults they can find.
Re: gearbox tcu
i have tcu in my glove box for the last 4yrs when i did manual swap,if you in need just msg me.Even if you only want to test it
Re: gearbox tcu
Hi all . still looking for a good tcu if any available
thanks
thanks
