gearbox tcu
111marc111
Re: gearbox tcu
Post by 111marc111 » Sun Mar 10, 2024 1:49 pm
https://www.ecutesting.com/product-cata ... nsmission/
Try this website. Heard good things about them and subsequently I'm sending my abs unit off to them for repair Monday.
The website suggests the can supply a new TCU, I suspect refurbed, but they can also rebuild yours or at least diagnose it and prove it to be ok.
Might be worth a shot.
c4v8
Re: gearbox tcu
Post by c4v8 » Sun Mar 10, 2024 2:31 pm
mornung ,all codes for the tcu 18223 pressure control solenoid"A" control circuit high, status passive sporadic
Re: gearbox tcu
Post by Shoppinit » Sun Mar 10, 2024 5:02 pm
Ok. Not F125 related. Based on the info supplied I’d say it’s worth a punt to replace the TCU.
c4v8
Re: gearbox tcu
Post by c4v8 » Sun Mar 10, 2024 9:47 pm
Thanks all , will let the out come be known.
Frazz82
Re: gearbox tcu
Post by Frazz82 » Wed Mar 13, 2024 6:04 pm
I had the same issue, water leak through the bonnet cable soaked the TCU and was getting the same codes again an again but only if I turned ignition on an left it. Took a punt on a TCU and problem solved.
Felix2566
Re: gearbox tcu
Post by Felix2566 » Thu Mar 14, 2024 11:28 am
I used ECU testing to repair my ABS control module, can also recommend them.
They charge a nominal fee to test your module to see if there are any faults before the full fee to repair any faults they can find.
rs4wagon
Re: gearbox tcu
Post by rs4wagon » Thu Mar 14, 2024 9:08 pm
i have tcu in my glove box for the last 4yrs when i did manual swap,if you in need just msg me.Even if you only want to test it
c4v8
Re: gearbox tcu
Post by c4v8 » Tue Mar 19, 2024 9:50 pm
Hi all . still looking for a good tcu if any available
thanks
Users browsing this forum: No registered users and 305 guests
