Another oil leak - any advice?
5.0 V10 50v biturbo - 571 bhp
c3nturi0n
Re: Another oil leak - any advice?
Post by c3nturi0n » Sat Apr 04, 2020 5:14 pm
I’d suggest to check seals around oil pump.
I recently replaced PAS pump and as part of the job we replaced dozen or so seals... some were done preventatively while other ls were showing ‘wet’ signs.
2008 RS6 Avant (Monza Silver)
- Stage II MRC tune with gearbox (720PS/850Nm)
- MIJ Powerflow exhaust (non-res)
- H&R ARBs
Jim Haseltine
Post by Jim Haseltine » Sat Apr 04, 2020 6:14 pm
Having had a chance to sit down and take a really good look at the pics, the oil on the subframe seems to be too far back for the turbo oil lines which are forward of the drive shafts. I can't think of anything oil-related in that area as all of the engine is forward of the driveshafts. I suppose that it could be brake fluid from an overflowed reservoir but from experience (yes, I changed some pads without checking the fluid level :oops: ) it doesn't drain out there.
I'll slide under my car tomorrow and see if anything gives me a clue.
jbourne
Post by jbourne » Sun Apr 05, 2020 1:57 am
Ian, Jim, first off, thanks to you guys for your help. I don't know what this forum would do without you.
That said, I'd like to declare myself a huge turd. I feel about ten years older, and about $10K richer. I entirely forgot about the brake fluid; and check out these pics:
Although I never looked behind the brake cylinder before doing the job, I'm pretty sure it did NOT look like this:
Level looks pretty full as well.
The floor in the overnight garage was also dry, so whatever leaked, must have stopped.
I dumped about 5L of water on and around the brake cylinder, hoping it'll wash off some of the brake fluid residue and follow the same leakage path.
Jim Haseltine
Post by Jim Haseltine » Sun Apr 05, 2020 9:39 am
You've confirmed a thought I had late last night.
Then later on I thought 'Hang on, the plenem drains are there, why didn't my fluid leak there? Ah, because back then the drains were blocked with leaves and sh*t you idiot".
