I’d suggest to check seals around oil pump.
I recently replaced PAS pump and as part of the job we replaced dozen or so seals... some were done preventatively while other ls were showing ‘wet’ signs.
Another oil leak - any advice?
Re: Another oil leak - any advice?
2008 RS6 Avant (Monza Silver)
- H&R ARBs
- H&R ARBs
Jim Haseltine
Having had a chance to sit down and take a really good look at the pics, the oil on the subframe seems to be too far back for the turbo oil lines which are forward of the drive shafts. I can't think of anything oil-related in that area as all of the engine is forward of the driveshafts. I suppose that it could be brake fluid from an overflowed reservoir but from experience (yes, I changed some pads without checking the fluid level
) it doesn't drain out there.
I'll slide under my car tomorrow and see if anything gives me a clue.
Ian, Jim, first off, thanks to you guys for your help. I don't know what this forum would do without you.
That said, I'd like to declare myself a huge turd. I feel about ten years older, and about $10K richer. I entirely forgot about the brake fluid; and check out these pics:
Although I never looked behind the brake cylinder before doing the job, I'm pretty sure it did NOT look like this: Level looks pretty full as well. The floor in the overnight garage was also dry, so whatever leaked, must have stopped.
I dumped about 5L of water on and around the brake cylinder, hoping it'll wash off some of the brake fluid residue and follow the same leakage path.
Jim Haseltine
You've confirmed a thought I had late last night.
Then later on I thought 'Hang on, the plenem drains are there, why didn't my fluid leak there? Ah, because back then the drains were blocked with leaves and sh*t you idiot".Last night I wrote: ↑Sat Apr 04, 2020 6:14 pmI suppose that it could be brake fluid from an overflowed reservoir but from experience (yes, I changed some pads without checking the fluid level) it doesn't drain out there.
Users browsing this forum: Google [Bot] and 19 guests
