Oil Level greyed out in MMI
5.0 V10 50v biturbo - 571 bhp
Toady1
Re: Oil Level greyed out in MMI
Post by Toady1 » Fri Sep 21, 2018 8:27 pm
ATinOf wrote:
Thu Sep 20, 2018 6:50 pm
Yes, same process
I do wonder if some people have ever heard of a search engine on the internet :bash:
Nope tried it and it definately doesn't work on my car! :boohoo:
Stiggles
Post by Stiggles » Fri Sep 21, 2018 9:48 pm
Yes, same process
The hidden menu needs to be enabled through Vagcom from what I gather, tried it myself earlier to no avail!
ATinOf
Post by ATinOf » Fri Sep 21, 2018 10:22 pm
VCDS: 2G Hidden menu enable;
  • Connect with module 07 – Control Head.
  • Choose procedure 10 – Adaptation.
  • Choose Channel 8.
  • Read stored value. By default it should be 0.
  • Change value to 1 and save it.
  • Read stored value. Now it should be 1.
  • Exit.
Reset MMI;
Locate buttons:
  • SETUP button
  • big control knob
  • upper-right soft button
Press and hold those buttons at the same time.
After two seconds release buttons.
Audi MMI screen will go black for few seconds and system will reboot.
Then To view Hidden Menu;
  • Press and hold together button: SETUP & CAR (or MENU & CAR).
ATinOf
Post by ATinOf » Fri Sep 21, 2018 10:24 pm
I will warn you - once you have enabled your oil level feature and used it and compared it to dipstick measuring you wont exactly be blown away with its accuracy
Stiggles
Post by Stiggles » Fri Sep 21, 2018 11:36 pm
That bad? I don't think I'll even bother with it, was just curious about the hidden menu.
I normally have my tyre pressure displayed or else have the display turned off.
Toady1
Post by Toady1 » Mon Sep 24, 2018 8:13 pm
Thanks #ATinOf! got it working with VCDS. Well got it to the greyed out bit, now need to change the setting to 5.....
Toady1
Post by Toady1 » Thu Sep 27, 2018 12:46 pm
I can't seem to find where to change the setting to 5 on mine. Its a 2008 model with 2G? I've enabled the oil level in VCDS but it is now greyed out, and the 2G MMI isn't the same menu wise as the YouTube vide? Any ideas? I'm now in the same boat as the OP.
twr_jaguar
Post by twr_jaguar » Fri Nov 23, 2018 11:31 am
Tried enabling on my car but its greyed out as well. I still have the dipstick but I'm guessing the 4F only has a low oil switch as oppose to a level sensor
2008 Daytona Grey RS6 - Secondary Decat MRC Stage 2 Map
1989 Jaguar XJR Janspeed 3.6 Bi-Turbo
2016 Triumph Tiger800 XCA
Toady1
Post by Toady1 » Fri Nov 23, 2018 12:36 pm
No idea, not managed to get mine to work yet.....just enabled but greyed out. 2008 car.
Users browsing this forum: Google [Bot] and 92 guests
