Nope tried it and it definately doesn't work on my car!
Oil Level greyed out in MMI
Re: Oil Level greyed out in MMI
The hidden menu needs to be enabled through Vagcom from what I gather, tried it myself earlier to no avail!
VCDS: 2G Hidden menu enable;
Locate buttons:
After two seconds release buttons.
Audi MMI screen will go black for few seconds and system will reboot.
Then To view Hidden Menu;
- Connect with module 07 – Control Head.
- Choose procedure 10 – Adaptation.
- Choose Channel 8.
- Read stored value. By default it should be 0.
- Change value to 1 and save it.
- Read stored value. Now it should be 1.
- Exit.
Locate buttons:
- SETUP button
- big control knob
- upper-right soft button
- Press and hold together button: SETUP & CAR (or MENU & CAR).
I will warn you - once you have enabled your oil level feature and used it and compared it to dipstick measuring you wont exactly be blown away with its accuracy
That bad? I don't think I'll even bother with it, was just curious about the hidden menu.
I normally have my tyre pressure displayed or else have the display turned off.
Thanks #ATinOf! got it working with VCDS. Well got it to the greyed out bit, now need to change the setting to 5.....
twr_jaguar
Tried enabling on my car but its greyed out as well. I still have the dipstick but I'm guessing the 4F only has a low oil switch as oppose to a level sensor
2008 Daytona Grey RS6 - Secondary Decat MRC Stage 2 Map
1989 Jaguar XJR Janspeed 3.6 Bi-Turbo
2016 Triumph Tiger800 XCA
No idea, not managed to get mine to work yet.....just enabled but greyed out. 2008 car.
