8 Speed ZF8hp from C7 RS7 and RS6 retrofit.
welwynnick
Re: 8 Speed ZF8hp from C7 RS7 and RS6 retrofit.
I'd be grateful for a bit of help on this. I need to gather some information.
If someone has either a C6 or C7 S6/S7/RS6/RS7 in the air for any reason, could you please measure the overall length of the gearbox from bellhousing mounting flange to the output shaft flange, and also the overall length of the prop-shaft to the rear axle, again measured between the coupling flanges?
The ZF 8HP has a splined output shaft, so it would need a different or modified prop-shaft.
Thanks in advance for your help.
Nick
Nick
Jim Haseltine
I tried yesterday afternoon but my car now isn't high enough for me to take accurate measurements and the front UV joint heat shield is back on too - something I don't want to take off a third time. A couple of weeks back when the car was higher and I had the engine dropped it would have been easy(ier) but manipulating a tape measure when there was only an inch or so between my face and the bottom of the car was a non-starter - sorry. Don't think I'll have to lift the car any higher again before I'm finished with this job but if that happens I'll see what I can do.
welwynnick
Thanks anyway Jim. I don't have a good solution to the propshaft problem, I'll just work something out when I get there, but leaving myself flexibility and options will help.
It would be wonderful if the RS7 propshaft would just drop straight in, but that may be too much to hope for.
Of course I may just have to have to have a custom shaft made.
Now the rear diff......
k1llertech
Hey welwynnick, looking forward to your updates. I'm searching everywhere for such info. I'm not a technical person, but I really hope you can make it. I talked with some mechanics, and their only concern is with the TCU and the ECU. From their prospective the fitting is not such a big deal.
Stay safe.
Stay safe.
welwynnick
If that was the extent of the problem, I think someone would have done this by now. I heard that someone did it with a BMW, but he used one of the aftermarket TCUs.k1llertech wrote: ↑Sat Mar 27, 2021 6:41 pmI talked with some mechanics, and their only concern is with the TCU and the ECU.
I have a long list of challenges ahead, and though I've already overcome some of them, what worries me is what I haven't thought about.
As an example, there are about 4000 different versions of the 8HP, and how do we know which one to use?
But if your mechanics know more than I do, I'd appreciate all the help I can get. I doubt if I can do it all myself.
Nick
welwynnick
One of the mechanical hurdles that has to be overcome is the rear axle. Since Audis have the front differential in the gearbox, the final drive will be whatever is in the gearbox, and the final drive ratio with it. I don't think you can change the crown wheel.
Unfortunately, the 8HP generally has a different final drive ratio to any of the 6HP transmissions that it replaces. You can't really expect the centre diff to accommodate the speed difference; I think it would overheat and wear out in pretty short order.
Therefore you really need the rear differential from the same doner car as the gearbox. And that will inevitably be somewhat different to the RS6 C6 rear axle. That will need some proper mechanical engineering for the mounting yoke. As with many things, there is at least a lot of commonality with VAG drive shaft flanges. They're 6 x 115mm for many cars from my A5 2.0 manual to the ZF 8HP.
Nick
Nick
welwynnick
For the record I thought I'd list the advantages with using the 8HP over the 6HP. It's stating the obvious, but it's quite a good list:
Good reliability
High torque capacity
High efficiency
Low first gear
High top gear
Close ratios
Quick gear shifts
Smooth gear shifts
Shared architecture
Improved performance
Reduced fuel consumption
Reduced emissions
These are the integration problems that I think I have solutions for:
Which doner car
Bellhousing
Flywheel
Starter motor
Front drive shafts
Mechanical control
Electrical power
Cooling
And these are the integration problems that I don't have solutions for:
Rear differential
Transmission mount
Prop-shaft
Parking lock
Electronic control
Security
Space
And these are the differences that I'm just going to ignore for now:
Stop/start control
Automated neutral
Dashboard display
Diagnostics
Nick
Good reliability
High efficiency
Low first gear
High top gear
Close ratios
Quick gear shifts
Smooth gear shifts
Shared architecture
Reduced emissions
Which doner car
Bellhousing
Flywheel
Starter motor
Front drive shafts
Mechanical control
Electrical power
Cooling
Rear differential
Transmission mount
Prop-shaft
Parking lock
Electronic control
Security
Space
Stop/start control
Automated neutral
Dashboard display
Diagnostics
Nick
welwynnick
Up to now it's all been a bit academic as I don't own an RS6. However, I don't think tinkering with the gearbox on the car would be very easy, so I'm taking a different approach, so I can build up some confidence before actually making the plunge.
I'm going about things the wrong way round by proving the easy solutions before tackling the difficult things, but I've committed myself now. I've bought an 8 speed gearbox to play with. It's from a low mileage write-off and seems to be in good condition.
Sadly I couldn't do a trial fit in my A5 when I was replacing the clutch. I'm pretty sure some quattro versions of the A4 and A5 use the 6HP box, and if the 8HP would fit in there, I think it would go anywhere. Now I have a nagging doubt, as it's a big transmission.
welwynnick
Well, there are lots of pieces to this puzzle, and I just got another one. I thought I'd try to find a scrap RS6 or S6 engine, but it turns out there aren't very many of them.
However I did find an R8 engine, and I've had to find some space in my shockingly cluttered garage.
It's not exactly what I was looking for, but the possibility of having an actual Lambo engine in an RS6 was intriguing. After all, they are the same engine, aren't they?
Nick
Nick
Supposedly the only similarity between both engines is the block. Everything else is different.
Volvo XC90
C7 - RS6
C6 - RS6
B5 - RS4
C7 - RS6
C6 - RS6
B5 - RS4
welwynnick
What's your source of information? Here's a picture of the back of the R8 V10 engine:
And here's a picture of the back of the RS6 V10 engine:
EDIT: Notice the R8 has the power steering pump in the bottom left corner, and the aperture for the front diff propshaft in the bottom right corner.
Makes you wonder why Audi made a completely different block from the lambo one....then stamped a lambo bull on it....
Ferrari 296 GTB
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Belmont SRi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
1st car Datsun 120 FII Lime green....yeah
992 Turbo S
Ferrari 488 Spider
C6 RS6
E46 M3 convertible
Nissan 200sx mk 2
Vauxhall Senator
Ford Sierra 1.8LX
Peugeot 205 1.9 GTi
Vauxhall Astra 1.3
Vauxhall Astra 1.3
I'm pretty sure the block isn't the same as the 5.2 but the first gen 5.0 gallardo, but given the displacement difference and having seen countless pieces of information stating that the C6 RS6 shared minimal parts with any 5.2 Lamborghini/R8 I would say it's safe to assume the block is one of the few shared pieces
The oil pump has a bull stamp on it, but I don't know if that is used in any other engines
welwynnick
The 5.0 Gallardo block had a bore spacing of 88.0 mm, same as many Audi 4 and 5 cylinder engines.I'm pretty sure the block isn't the same as the 5.2 but the first gen 5.0 gallardo,
All other Audi/ Lamborghini 90 degree V engines have a bore spacing of 90.0 mm, which includes the following:
3.2 V6
4.2 V8
5.0 V10 RS6
5.2 V10
welwynnick
I can answer some of this myself now, having unearthed some useful information buried deep in the internet.welwynnick wrote: ↑Fri Mar 26, 2021 10:13 amI'd be grateful for a bit of help on this. I need to gather some information.
Nick
The length of the RS6 C6 prop-shaft is 1759 mm (GKN says 1583)
The length of the RS6 C7 prop-shaft is 1649 mm (GKN says 1649)
The length of the RS4 B7 prop-shaft is 1529 mm
That doesn't actually tell me whether I can or can't use the C7 prop, as there are other variables:
The C7 has a wheelbase of 2912 mm vs 2843 mm for the C6, so the C7 is 69mm longer.
The ZF 8HP box is probably longer than the 6HP, so the prop may need to be shorter.
The 8HP has a splined rather than flanged output, so the prop needs to be longer.
The C7 has a different rear diff, but I don't know what the effect of this is.
Although the RS6 C7 has a different prop Part No to other A6 auto models, it's the same length, which suggests the 'box is the same length as lower capacity versions of the 8HP.
In other respects the B7, C6 and C7 props are similar - the tube diameter is 70mm and the diff flange has a 6 x 86 PCD
I am still trying to fit the 8HP, but haven't made much progress recently. This isn't much, but it's a little bit of information that I'll need.
Does anyone know if it's possible to split the prop-shaft into two?
Nick
Users browsing this forum: No registered users and 31 guests
