Will do mate, I've not even heard one with a Milltek to compare but i cant wait for some noise
as it sounds very tame with just the cat deletes.
i have supersprint which i think sounds slightly better than milltek, but i do need decat downpipes to get that little bit extra out of the remap ! I'm looking at getting some custom carbon airboxes made up but its proving hard to find someone who is willing to make some ... as you will find out heat is a big problem with the c6
Yes i have pretty much had everything carbon'd you can think of, from steering wheels, seat backs, scuttle panels, rs4 enginers6_sid wrote: ↑Thu Apr 06, 2017 4:08 pmi have supersprint which i think sounds slightly better than milltek, but i do need decat downpipes to get that little bit extra out of the remap ! I'm looking at getting some custom carbon airboxes made up but its proving hard to find someone who is willing to make some ... as you will find out heat is a big problem with the c6
Ha Ha
Had a rummage through the MK archives..... 3 years back April 2014.
I drove Shivs and wasnt too bad to be honest but didnt really push it hard.Jules wrote: ↑Fri Apr 07, 2017 4:10 pm
Ha Ha
Well I have been in talks about a full on custom kit built totally for this car using all bilstein components so lets see.
Airlift do a kit but atm I'm unsure, I'm told it drives well but I also know about one strut losing oil and going down the
lines which I assume is due to the weight on the front end.
I've also spoke to H+R in Germany about the ultra lows so I need to see what ground clearance these things have.
A20LEE wrote:Mines lowered as far as it will go on KW Adjustable platforms, i'd like it a bit lower if im honest but its rubbing already so would need narrower tyres and coilovers/Air. However i wanted to retain the DRC with mine being a lower miler and just so i can switch comfort to much firmer if i want to push it. I'd go of the KW's again but with a slightly shorter spring or leave out the helper springs.
These are hard to get low, theres over 150mm ground clearance at a guess. The wheel size is also an issue, I considered ordering a 275/30 rather than 275/35
Andyevo wrote: ↑Sat Apr 08, 2017 7:37 amA20LEE wrote:Mines lowered as far as it will go on KW Adjustable platforms, i'd like it a bit lower if im honest but its rubbing already so would need narrower tyres and coilovers/Air. However i wanted to retain the DRC with mine being a lower miler and just so i can switch comfort to much firmer if i want to push it. I'd go of the KW's again but with a slightly shorter spring or leave out the helper springs.
Got any pics of yours on kw set on lowest setting please?
That looks awesomeA20LEE wrote:Andyevo wrote: ↑Sat Apr 08, 2017 7:37 amA20LEE wrote:Mines lowered as far as it will go on KW Adjustable platforms, i'd like it a bit lower if im honest but its rubbing already so would need narrower tyres and coilovers/Air. However i wanted to retain the DRC with mine being a lower miler and just so i can switch comfort to much firmer if i want to push it. I'd go of the KW's again but with a slightly shorter spring or leave out the helper springs.
Good find thanks mate
No on these it cant be done using the drc struts unfortunatelyGolfather wrote: ↑Sat Apr 08, 2017 12:02 amI drove Shivs and wasnt too bad to be honest but didnt really push it hard.Jules wrote: ↑Fri Apr 07, 2017 4:10 pm
Ha Ha
The struts though were skinny as fook so doubt it would have lasted with all that weight.
Wonder if you can bag it though retaining the DRC struts?
