Will do mate, I've not even heard one with a Milltek to compare but i cant wait for some noise
as it sounds very tame with just the cat deletes.
i have supersprint which i think sounds slightly better than milltek, but i do need decat downpipes to get that little bit extra out of the remap ! I'm looking at getting some custom carbon airboxes made up but its proving hard to find someone who is willing to make some ... as you will find out heat is a big problem with the c6
Yes i have pretty much had everything carbon'd you can think of, from steering wheels, seat backs, scuttle panels, rs4 enginers6_sid wrote: ↑Thu Apr 06, 2017 4:08 pmi have supersprint which i think sounds slightly better than milltek, but i do need decat downpipes to get that little bit extra out of the remap ! I'm looking at getting some custom carbon airboxes made up but its proving hard to find someone who is willing to make some ... as you will find out heat is a big problem with the c6
Ha Ha
Had a rummage through the MK archives..... 3 years back April 2014.
I drove Shivs and wasnt too bad to be honest but didnt really push it hard.Jules wrote: ↑Fri Apr 07, 2017 4:10 pm
Ha Ha
Well I have been in talks about a full on custom kit built totally for this car using all bilstein components so lets see.
Airlift do a kit but atm I'm unsure, I'm told it drives well but I also know about one strut losing oil and going down the
lines which I assume is due to the weight on the front end.
I've also spoke to H+R in Germany about the ultra lows so I need to see what ground clearance these things have.
A20LEE wrote:Mines lowered as far as it will go on KW Adjustable platforms, i'd like it a bit lower if im honest but its rubbing already so would need narrower tyres and coilovers/Air. However i wanted to retain the DRC with mine being a lower miler and just so i can switch comfort to much firmer if i want to push it. I'd go of the KW's again but with a slightly shorter spring or leave out the helper springs.
These are hard to get low, theres over 150mm ground clearance at a guess. The wheel size is also an issue, I considered ordering a 275/30 rather than 275/35
Andyevo wrote: ↑Sat Apr 08, 2017 7:37 amA20LEE wrote:Mines lowered as far as it will go on KW Adjustable platforms, i'd like it a bit lower if im honest but its rubbing already so would need narrower tyres and coilovers/Air. However i wanted to retain the DRC with mine being a lower miler and just so i can switch comfort to much firmer if i want to push it. I'd go of the KW's again but with a slightly shorter spring or leave out the helper springs.
Got any pics of yours on kw set on lowest setting please?
That looks awesomeA20LEE wrote:Andyevo wrote: ↑Sat Apr 08, 2017 7:37 amA20LEE wrote:Mines lowered as far as it will go on KW Adjustable platforms, i'd like it a bit lower if im honest but its rubbing already so would need narrower tyres and coilovers/Air. However i wanted to retain the DRC with mine being a lower miler and just so i can switch comfort to much firmer if i want to push it. I'd go of the KW's again but with a slightly shorter spring or leave out the helper springs.
Good find thanks mate
No on these it cant be done using the drc struts unfortunatelyGolfather wrote: ↑Sat Apr 08, 2017 12:02 amI drove Shivs and wasnt too bad to be honest but didnt really push it hard.Jules wrote: ↑Fri Apr 07, 2017 4:10 pm
Ha Ha
The struts though were skinny as fook so doubt it would have lasted with all that weight.
Wonder if you can bag it though retaining the DRC struts?
Users browsing this forum: No registered users and 289 guests
