Help All 4 wheels buckled
MrBadger
Re: Help All 4 wheels buckled
Post by MrBadger » Tue Jun 28, 2016 2:55 pm
Sorry to hear that Scottie. I don't think people in the rest of the U.K. let alone Europe appreciate how bad most of our roads are in central Scotland. However they are the normal roads in a country Audi have many dealers and target customers. A single bent wheel would say pothole (need to claim the Council) or kerb (user error). However as you say no other damage and it's all wheels therefore the only logical conclusion is that they are not fit for purpose in a market Audi target. Hopefully they will see sense and good luck.
2006 B7 RS4 Black Saloon
Markp
Post by Markp » Tue Jun 28, 2016 5:51 pm
They may have Hunter but are you sure it is Road Force with the roller that simulates the road. I know Bentley garages often have them but Audi? I doubt it.
See here for uk locator
http://www.balancemycar.co.uk
Gareth_rs6
Post by Gareth_rs6 » Wed Jun 29, 2016 6:42 am
...I wonder if this is the cause of this issue... viewtopic.php?f=76&t=120802
Mine has the black optional wheels, as well.
scottie1979
Post by scottie1979 » Wed Jun 29, 2016 11:40 am
Gareth sure does sound like the same symptoms
When it was in they re-balanced the wheels and it is slightly better. Still waiting for Audi UK feedback.
Got some nice silver weights on my nice black wheels right between the spokes :audibash:
Post by MikeFish » Wed Jun 29, 2016 12:20 pm
So possibly a bad tyre batch where the glue holding the foam has not worked and the foam has come away causing an imbalance in the tyres? This would explain the symptoms and why it hasn't always done it and why there is no visible damage to the wheels.
Eddie555
Post by Eddie555 » Wed Jun 29, 2016 12:30 pm
It would be a costly but interesting to completely change the tyres over to MPSS's or a non silent tyre and see if that solves the problem.s
Current ride’s
Previous rides
Post by MikeFish » Wed Jun 29, 2016 1:07 pm
It would be cheaper for Audi to provide 4 new tyres rather than wheels to try and eliminate the problem.
Or even just remove the tyres and check the foam in the tyre.
scottie1979
Post by scottie1979 » Wed Jun 29, 2016 1:17 pm
this is the unit they balanced the wheels with.
Not sure what it is.
Eddie555
Post by Eddie555 » Wed Jun 29, 2016 1:22 pm
When I had my car I hit a pothole really hard. I was braking really hard at the time so you can imagine the force of slowing from a biggish speed adding extra kinetic energy as I literally smashed into the pothole. It sounded like my suspension had collapsed. I had the wheel checked over a few days later and it was fine. Maybe it was a lucky escape but I'd say the wheels are tough and wouldn't say they can buckle easy.
Current ride’s
Previous rides
almoRS
Post by almoRS » Wed Jun 29, 2016 1:54 pm
I drove over a kerb in mine at low speed and burst both tyres on passenger side. I was convinced wheels or suspension would be damaged or buckled but apart from minor scrapes nothing wrong with them after 2 new tyres fitted. I've commented in the other thread about the foam as the "buzzing" has returned after hitting a pothole. It is an expensive fix but do wonder about putting Michelin MPSS on without the foam stuff. I want different wheels though if I'm doing that :)
RS3 Saloon, Merlin Purple, incoming.....
S3 Sportback Black Edition, Panther Black, BBS CHs
Previous:
RS6 C7 Riviera Blue, Carbon Pack, Sports exhaust, BC Forged HS04
C63 AMG Coupe, Fire Opal Red, Performance Pack, HRE P44SC's
RS4 B7 Saloon, Avus Silver, HRE P40s, Tubi exhaust
Volvo S60 R Black Saphire, Evolve Suspension + aerodynamics, BMC
Volvo S40 T4 Standard
Markp
Post by Markp » Wed Jun 29, 2016 4:36 pm
Looks like that balancer has a roller so probably RF, albeit usually red.
feeltheburn
Post by feeltheburn » Wed Jun 29, 2016 6:14 pm
Sorry to hear about your vibration issues. £5K is a fair spend if indeed buckled wheels are the issue. Why not get yourself down to tool station and buy a magnetic base and a dial indicator, chock three wheels, car in neutral, jack up the remaining wheel, set the magnetic base on the ground and indicator up such that it touches the rim and them turn the wheel manually and check for run out [magnetic base in this case is just to reliably hold the dial indicator rather than mount to a metallic surface]. I'd probably tape up the alloy where the dial gauge would run just to ensure no scraping. Easy to do and well worth it given the potential £5K bill! This is unlikely to show if the wheels are oval rather than buckled though.
I also recommend the MPSS over the Continental tyres (if that is what you have) as some of the handling issues are lessened, however I never had any vibration issues with the continentals.
Found this regarding how to do it on the inside of the wheel- using the "inner" side of the wheel you could also check for oval wheels.
http://www.newtonnet.co.uk/coupe/servic ... p@id=12506
RS6 C7 (2014), Daytona Pearl, 21" Titanium, On Air, LEDs, Sports Exhaust, Dynamic Steering, Red Calipers, ACC, Top View, Connect, Tints, Rear Side Airbags, Rear heated seats; MP4S
Shinobi675
Post by Shinobi675 » Wed Jun 29, 2016 10:00 pm
I once hit a curb at 40mph going down Feltham high street at 2am. Both wheels up on the curb!
And those wheels, solid wheels, never going to buckle wheels.
Destroyed them! :) poor Astra. I was only about 17 at the time.
Post by MikeFish » Thu Jun 30, 2016 12:16 am
Shinobi675 wrote:I once hit a curb at 40mph going down Feltham high street at 2am. Both wheels up on the curb!
:drink: :drink: :drink:
SuprSi
Post by SuprSi » Thu Jun 30, 2016 12:40 am
feeltheburn wrote:Sorry to hear about your vibration issues. £5K is a fair spend if indeed buckled wheels are the issue. Why not get yourself down to tool station and buy a magnetic base and a dial indicator, chock three wheels, car in neutral, jack up the remaining wheel, set the magnetic base on the ground and indicator up such that it touches the rim and them turn the wheel manually and check for run out [magnetic base in this case is just to reliably hold the dial indicator rather than mount to a metallic surface]. I'd probably tape up the alloy where the dial gauge would run just to ensure no scraping. Easy to do and well worth it given the potential £5K bill! This is unlikely to show if the wheels are oval rather than buckled though.
That's a bloody good idea. It's usually not easy to see if the wheels deformed without it actually spinning on a ballancer in front of you.
Users browsing this forum: No registered users and 195 guests
