10mm RS4 H&R spacers x4
Re: 10mm RS4 H&R spacers x4
Post by MikeFish » Tue Jul 26, 2016 9:49 pm
Why wouldn't you just buy the right size ones? For me spigot rings are fine if you really want a set of wheels hat only come in a certain size, but there is no reason to buy the wrong size spacers when there are ones of the right size readily available. You are unnecesarily risking wheel wobble if you ask me, but yes I can't see why a spigot wouldn't work.
FaisalJ
Post by FaisalJ » Tue Jul 26, 2016 11:51 pm
A spigot might get the spacer sitting nice and snug on the hub. However, if you have a wheel with a 57.1 centre bore, it won't go onto the spacer (unless it's an aftermarket wheel with a large centre bore that has been reduced with a spigot ring, that could be swapped).
Best to just get the correct spacers. If you don't want to fork out for H&R's, there are cheaper hubcentric spacers on eBay.
2007 RS4 B7 Avant
RossDagley
Post by RossDagley » Wed Jul 27, 2016 9:42 am
Starry wrote:
MikeFish wrote:Yes I think rspj posted a thread showing how they look on his car. Haven't you got a B7 anyway? These are for a B8 which has a bigger centre bore.
would they not work with a spigot ring?
The B8 has the larger centre bore. So you could fit a spigot ring to the B7 and make the spacers fit, but how would you then fit your wheels to the (larger bore) spacers?
Previously:
Starry
Post by Starry » Wed Jul 27, 2016 7:53 pm
B8 wheels it is then..... :beerchug: you talked me into it..
to be honest i didn't see the b8 reference in the post so was the spigot was just me thinking out loud..
2006 RS4
Phantom black
MRC Stage 2, Milltek non res, pre cat delete,
Post by MikeFish » Wed Jul 27, 2016 7:56 pm
Starry wrote: B8 wheels it is then..... :beerchug: you talked me into it..
:nodder: :nodder: :nodder:
Starry
Post by Starry » Wed Jul 27, 2016 9:21 pm
That sits just right..... :thumbs:
2006 RS4
Phantom black
Post by MikeFish » Wed Jul 27, 2016 9:41 pm
Starry wrote:That sits just right..... :thumbs:
FYI, that's with no spacers so if you go for a set of B8 RS alloys, whether it's the Rotors or the V spokes, you shouldn't need any spacers anyway (but you will need spigots).
Starry
Post by Starry » Wed Jul 27, 2016 9:51 pm
Thanks for the info, I'm thinking of going with the S5 20" alloys, the ones that look like rs4 b7's. Stock look but a larger wheel.
2006 RS4
Phantom black
Post by MikeFish » Wed Jul 27, 2016 9:57 pm
Good choice, I nearly went for those to.
Users browsing this forum: No registered users and 94 guests
