10mm RS4 H&R spacers x4
Re: 10mm RS4 H&R spacers x4
Why wouldn't you just buy the right size ones? For me spigot rings are fine if you really want a set of wheels hat only come in a certain size, but there is no reason to buy the wrong size spacers when there are ones of the right size readily available. You are unnecesarily risking wheel wobble if you ask me, but yes I can't see why a spigot wouldn't work.
A spigot might get the spacer sitting nice and snug on the hub. However, if you have a wheel with a 57.1 centre bore, it won't go onto the spacer (unless it's an aftermarket wheel with a large centre bore that has been reduced with a spigot ring, that could be swapped).
Best to just get the correct spacers. If you don't want to fork out for H&R's, there are cheaper hubcentric spacers on eBay.
2007 RS4 B7 Avant
- RossDagley
- Top Gear
The B8 has the larger centre bore. So you could fit a spigot ring to the B7 and make the spacers fit, but how would you then fit your wheels to the (larger bore) spacers?Starry wrote:would they not work with a spigot ring?MikeFish wrote:Yes I think rspj posted a thread showing how they look on his car. Haven't you got a B7 anyway? These are for a B8 which has a bigger centre bore.
Previously:
Previously:
B8 wheels it is then.....RossDagley wrote:The B8 has the larger centre bore. So you could fit a spigot ring to the B7 and make the spacers fit, but how would you then fit your wheels to the (larger bore) spacers?Starry wrote:would they not work with a spigot ring?MikeFish wrote:Yes I think rspj posted a thread showing how they look on his car. Haven't you got a B7 anyway? These are for a B8 which has a bigger centre bore.
to be honest i didn't see the b8 reference in the post so was the spigot was just me thinking out loud..
That sits just right.....
ThanksStarry wrote:That sits just right.....
FYI, that's with no spacers so if you go for a set of B8 RS alloys, whether it's the Rotors or the V spokes, you shouldn't need any spacers anyway (but you will need spigots).
Thanks for the info, I'm thinking of going with the S5 20" alloys, the ones that look like rs4 b7's. Stock look but a larger wheel.MikeFish wrote:ThanksStarry wrote:That sits just right.....
Good choice, I nearly went for those to.
Users browsing this forum: Google [Bot] and 38 guests
