ABS & Traction control light stayed on.
Re: ABS & Traction control light stayed on.
You mean you sent the ABS module for repairs, it was repaired and you fitted it back, but you still have problems?
- audi_driver79
No I havent yet. I have just bought VCDS as recommended by virtually everyone! I am going to test the speed sensors as I drive then fix that and see about the maf problem. I had read and it was Shopinnit who said on a different forum that maf problems can cause incorrect fuel mixture and could be a contributor to the torque converter clutch fault and is the air quality sensor related? If I fix the maf hopefully the clutch problem won't mean I am on my way to a big bill?. Anyway here are the faults from the scan this afternoon if anyone would like to comment?? Please.....
Address 01: Engine Labels: 077-907-558-BCY.lbl
Part No: 4D1 907 558
Component: 4.2l V8/5VT G 0002
Coding: 0010752
Shop #: WSC 00000 000 08192
VCID: 6BCDD647D385056ADA52491-5140
2 Faults Found:
17416 - Mass Air Flow Sensor 1/2
P1008 - 004 - Implausible Signal - Intermittent
16885 - Vehicle Speed Sensor
P0501 - 004 - Implausible Signal - MIL ON
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01L-927-156.lbl
Part No: 4B0 927 156 FB
Component: AG5 01L 4.2l5VT RdW 1315
Coding: 00001
Shop #: WSC 00000
VCID: 6CCFD55BD68B0752D358725-515E
1 Fault Found:
17125 - Torque Converter Clutch
P0741 - 35-00 - Stuck OFF / No Power being transferred
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 AD
Component: ESP 5.7 RS 6 2310
Coding: 06697
Shop #: WSC 00000
VCID: 63DDBE673B55482A6282911-515E
1 Fault Found:
00283 - ABS Wheel Speed Sensor; Front Left (G47)
30-00 - Open or Short to Plus
Address 08: Auto HVAC Labels: 4B0-820-043-MY2.lbl
Part No: 4B0 820 043 AM
Component: A6-Klimavollautomat 0105
Coding: 00001
Shop #: WSC 00000
VCID: 65D9A07F3561361A8C968F9-2586
1 Fault Found:
01592 - Air Quality Sensor (G238)
37-00 - Faulty
There aren't anymore after this I am worried about.....
Coding: 0010752
2 Faults Found:
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
Coding: 06697
Shop #: WSC 00000
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
1 Fault Found:
37-00 - Faulty
C5 RS6 Avant Mugello Blue, Original Springs.
2001 A2 1.4tdi 75bhp. Runs on fresh air!
The air quality sensor is nothing. Ignore.
You need to sort the maf out and the speed sensor then see what happens.
I suspect the TC stuck open is going to be a permanent DTC, but it's worth trying to clear the others.
- audi_driver79
Phew! Thanks Shop!
- audi_driver79
I had a chance to have a look at the speed sensor and the wire ets seems fine. I put a multimeter across it and the figures didn't seem to be wildly fluctuating. I also used VCDS and checked the speed sensors with the measuring blocks and they all seemed to indicate the same speeds despite the abs light being on. Surely if the light was on the front left sensor would give no reading?
As I said before, the speed sensor on mine was probably fine so when it was replaced so it made no difference.
You really need to follow the wiring loom to the ABS pump/ECU and see whether it makes a difference when you twist it about. That's how AMD found the fault on mine although it was still indicating a fault on the left speed sensor which has just been changed.
- audi_driver79
Swapped the sensors and although I haven't ran the car the fault was still there and didn't clear. I guess the wiring will be accessible if I manoeuvre the module out the way, job for tomorrow. Btw the resistance of the speed sensors is between 1.6 / 1.7
Users browsing this forum: Google [Bot] and 301 guests
