Rnse startup volume
Surrey Sam
Re: Rnse startup volume
Post by Surrey Sam » Thu Sep 03, 2015 9:24 am
rob-s wrote:I wonder if the BT telephone default volume could be adjusted? Mine is very loud at first call.
I think that can also be changed in the Adaption Channel of the Telephone Module using VCDS.
harding
Post by harding » Thu Sep 03, 2015 6:36 pm
Warning!
Performing this procedure may cause permanent damage to your car.
Do this at your own risk!
We are not responsible for any loss or damage.
:shock: :shock: :shock: :shock: :shock: :shock:
Is it also in that hidden menu you can change what start up page the FIS is gonna show? Because entering the FIS menu there is nowhere do do this or hide the navigation and laptime pages.
Audi RS4 Avant
[2014]: blacked out wheels & grill: center res delete : flaps open
[2015]: brembo & yellowstuff : michelin pss : h&r spacers
[2016]: sachs performance clutch : decoked : led there be light : black window trim
[2017]: stertman stage 1 : black headlights & clear corner mod : gruppe m air intake : gutted resonators
PetrolDave
Post by PetrolDave » Thu Sep 03, 2015 8:10 pm
harding wrote:Is it also in that hidden menu you can change what start up page the FIS is gonna show? Because entering the FIS menu there is nowhere do do this or hide the navigation and laptime pages.
Nope, if the RNS-E has the compass enabled then the DIS will show the compass but if the compass is disabled then the DIS will show the same page it did when the ignition was turned off.
If you don't want the nav instructions to appear in the DIS then you have to change the value in adaptation channel 62 of the instruments to clear the nav bit.
AFAIK there is no way to hide the laptime page in the DIS.
harding
Post by harding » Thu Sep 03, 2015 8:43 pm
Thanks Dave!
Oh, and sorry about the FIS. Im more used to say that (Flight Information System) :oops:
Audi RS4 Avant
JmRS4
Post by JmRS4 » Sat Sep 05, 2015 6:10 pm
That's what the bottom setting is in radio test menu 3. Adjusting it doesn't change the start up volume Image. Anything else I can try?
JmRS4
Post by JmRS4 » Sun Sep 06, 2015 3:30 pm
Do these settings look correct? Cheers
Baz999
Post by Baz999 » Sun Sep 06, 2015 7:10 pm
Try loudness to off. I tried this the other day and it seemed to work when I turned the car off and on,but not been in the car past 2 days to see if it worked.
PetrolDave
Post by PetrolDave » Mon Sep 07, 2015 6:57 pm
It's actually the top line "Volume = 0" that you need to change to set the startup volume (if it will work for you...).
JmRS4
Post by JmRS4 » Mon Sep 07, 2015 7:49 pm
Tried adjusting the 'loudness' to off but no good. I can't seem to get access to the top volume. It goes up or down depending on the volume knob being moved but cant seem to make it stick. Thanks
