I think that can also be changed in the Adaption Channel of the Telephone Module using VCDS.rob-s wrote:I wonder if the BT telephone default volume could be adjusted? Mine is very loud at first call.
Rnse startup volume
- Surrey Sam
Re: Rnse startup volume
mikep99 wrote:cut n pasted from http://mr-fix.info/audi-rns-e-hidden-me ... ring-mode/
Warning!
Performing this procedure may cause permanent damage to your car.
Do this at your own risk!
We are not responsible for any loss or damage.
Is it also in that hidden menu you can change what start up page the FIS is gonna show? Because entering the FIS menu there is nowhere do do this or hide the navigation and laptime pages.
Audi RS4 Avant
[2014]: blacked out wheels & grill: center res delete : flaps open
[2015]: brembo & yellowstuff : michelin pss : h&r spacers
[2016]: sachs performance clutch : decoked : led there be light : black window trim
[2017]: stertman stage 1 : black headlights & clear corner mod : gruppe m air intake : gutted resonators
- PetrolDave
Nope, if the RNS-E has the compass enabled then the DIS will show the compass but if the compass is disabled then the DIS will show the same page it did when the ignition was turned off.harding wrote:Is it also in that hidden menu you can change what start up page the FIS is gonna show? Because entering the FIS menu there is nowhere do do this or hide the navigation and laptime pages.
If you don't want the nav instructions to appear in the DIS then you have to change the value in adaptation channel 62 of the instruments to clear the nav bit.
AFAIK there is no way to hide the laptime page in the DIS.
PetrolDave wrote:Nope, if the RNS-E has the compass enabled then the DIS will show the compass but if the compass is disabled then the DIS will show the same page it did when the ignition was turned off.harding wrote:Is it also in that hidden menu you can change what start up page the FIS is gonna show? Because entering the FIS menu there is nowhere do do this or hide the navigation and laptime pages.
Thanks Dave!
Oh, and sorry about the FIS. Im more used to say that (Flight Information System)
Audi RS4 Avant
Do these settings look correct? Cheers
Try loudness to off. I tried this the other day and it seemed to work when I turned the car off and on,but not been in the car past 2 days to see if it worked.
- PetrolDave
It's actually the top line "Volume = 0" that you need to change to set the startup volume (if it will work for you...).JmRS4 wrote:That's what the bottom setting is in radio test menu 3. Adjusting it doesn't change the start up volume. Anything else I can try?
Tried adjusting the 'loudness' to off but no good. I can't seem to get access to the top volume. It goes up or down depending on the volume knob being moved but cant seem to make it stick. Thanks
