Emissions light has come on.
Adamcell
Re: Emissions light has come on.
Post by Adamcell » Thu Nov 28, 2013 8:05 pm
PetrolDave wrote:
Adamcell wrote:So I'm guessing there is a vacuum leak somewhere. Would this be the reason why the emissions light is on?
Very probably.
Ok thanks Dave. Il try and get it checked out tomorrow.
nij
Post by nij » Thu Nov 28, 2013 8:25 pm
Adamcell wrote:I also forgot to say my car has a full Milltek fitted with sports cats so I'm starting to think this could be why the light is on.
Do you know if your car have been re-mapped by MRC? If you've got sport cats then you'll need to program out a couple of sensors as you have no pre-cats, otherwise it will trigger an emission light. This is what happen to mine until I had it re-mapped.
Mercedes E-Coupe 350CDi
Adamcell
Post by Adamcell » Thu Nov 28, 2013 8:34 pm
Hi and yea it has been mapped by mrc. The valves are staying closed even when the engine is off. They are quite dirty and maybe getting stuck, so I will give them a good clean tomorrow and hopefully they will work.
nij
Post by nij » Thu Nov 28, 2013 8:39 pm
The exhaust valves should open when the engine is off, as it require vacuum to close them.
Adamcell
Post by Adamcell » Thu Nov 28, 2013 8:57 pm
nij wrote:The exhaust valves should open when the engine is off, as it require vacuum to close them.
They must be just clogged up with crap then. Il have a play with them tomorrow. Thanks for your help.
Adamcell
Post by Adamcell » Fri Nov 29, 2013 5:41 pm
Quick update: Just had the car scanned and looks like it could be a lambda sensor. Just waiting For them to get back to me when they have checked the codes. Regarding the exhaust valves they aren't working still so I spoke to Milltek and they say it could be a solenoid. I may just get them cut out yet but we will see.
stuartbarriskell
Post by stuartbarriskell » Fri Dec 06, 2013 3:00 pm
Guys, not sure about the flap removal as I intend top sell my car shortly. Can anyone give an idea of costings involved versus fixing the problem proeprly. My EPC and Management light has came on and this appears to be the fault. Garage want a closer look on Monday coming.
Current stable: B8 RS4.
13 BMW HP4 Track/Road
21 BMW S1000RR Sold
04 ZX 10R Sold
MV Agusta Reparto Corse Sold
GoneB7 RS4
Gone B7 S4
Gone 1.8 T
Gone A3
Adamcell
Post by Adamcell » Sat Dec 07, 2013 8:57 pm
So far so good the light is off now. It turned out to be a lambda sensor which looks like it had been replaced by the garage I bought it from with a cheap part. So I had the car in at Pipewerx and had a genuine audi sensor fitted and all seems good now. I would highly recommend Pipewerx for exhaust work.
PetrolDave
Post by PetrolDave » Sun Dec 08, 2013 11:12 am
Adamcell wrote:looks like it had been replaced by the garage I bought it from with a cheap part.
I've heard so many people have problems with cheap lambda sensors, it seems anything other than a Bosch or genuine OE part is very likely to be a waste of hard earned cash.
adsgreen
Post by adsgreen » Sun Dec 08, 2013 12:43 pm
stuartbarriskell wrote:Guys, not sure about the flap removal as I intend top sell my car shortly. Can anyone give an idea of costings involved versus fixing the problem proeprly. My EPC and Management light has came on and this appears to be the fault. Garage want a closer look on Monday coming.
Need to know exactly which code(s).
If it is a single code code be the sensor which depending on whichever bank might be very cheap or very expensive (one can be done in place, the other needs the manifold off).
If it's one or both banks then could be stuck (needs to come off and cleaned), actuator (there are two), solenoid, vacuum leak, one way valve.
Chances are the manifold needs to come off and audi don't repair them so new is about 1200-1500 fitted from dealer.
Users browsing this forum: Flash and 173 guests
