Stealers, £1600 the lot inc fittingsutts wrote:At the stealers, or an Indie?klauster wrote:When I had mine done at 86k I had the whole thing done, clutch, flywheel and return pipe.... I went OEM
Clutch renewal
Re: Clutch renewal
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
Re: Clutch renewal
Indie (autotechnica) is
£100 clutch only
£1800 clutch and flywheel
I'm thinking either Sachs or loba now I think
£100 clutch only
Re: Clutch renewal
A new genuine clutch is about £230 + vat .....
Unit 20
0151 3366888
0151 3366888
Re: Clutch renewal
We use a higher grade of billet material for our single mass flywheel vs Sachs flywheel, ours has a higher coefficient of friction and is harder wearing , and lighter.TimDogg wrote:Grizz - some guys get the Sachs - do you recommend that over the Loba?
We can also supply the Sachs kit, id say at a unbeatable price too, i will add to LOBA website/shop in the new year, we don't actively push as feel ours is a better option.
Email : simon@turboengineering.de Phone : +44 (0)7825 884236 FaceBook : https://www.facebook.com/TheTurboEngineers
Re: Clutch renewal
I have now added SACHS own two options too our webshop
http://www.loba-motorsport.com/shop/aud ... s-quattro/
Re: Clutch renewal
I had a very occaisional slow returning clutch although no feeling through the pedal, mentioned it to the Dealer and they replaced the clutch return pipe FOC. However, if anything this has made the problem worse and my car now has an occaisional sticking pedal which is a horrible feeling when driving the car. From this experience I would not assume that doing the CRP alone would cure a sticking pedal.
spikeyboy101
Re: Clutch renewal
TBH i think most people have stated that changing the CRT hasnt made any difference to a sticking pedal - but if you got it done FOC then no harm done.
Only thing that fixed mine was a new Dual Mass Flywheel and Clutch - my fly wheel had given up the ghost big time, clutch was only 60% worn, Garage had a nightmare getting the flywheel and sprocket out is was than nackered.
Mine was sticking every sprinted drive, and was very slow to return with normal driving.
Other than than i think its the clutch return bearing that causes the sticking clutch.
Clutch renewal
New clutch, that's the bottom line.
Current;
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
66 Sapphire BMW F80 M3.
18 Mythos Black RS4
14 Daytona Grey RS6
08 Monza Silver RS6 Avant
07 Phantom Black RS4 Avant
Loads of BM's inc. 4 x M's
18 Daytona Grey RS4
16 Green R8
Past;
17 Misano RS6 PE
18 Mythos Black RS4
14 Daytona Grey RS6
- Tile Diver
Re: Clutch renewal
+1vestax32 wrote:New clutch, that's the bottom line.
I wasn't having any issues with regards to the return of the clutch pedal, but did find it virtually impossible to get the car into first or reverse. So to the stealers it was, I instructed them to check the less expensive potential causes first, bleed the clutch, return pipe stuff like that, no issues were found with them. So gearbox out and new friction plate, pressure plate and bearing fitted, I also had them replace the clutch master cylinder and the return pipe anyway. Car all back together and all good, although I'm €2400 lighter in the wallet!!!
Worth it though!!
Black Optics / Ti Pack
SS Suspension +
Sunroof
H&R Hubcentric Spacers
Milltek Res / Valved Cat Back
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
If in doubt.. Power out!!
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Re: Clutch renewal
What determines if the flywheel needs done and what's the possible impact if you don't do it when replacing the clutch?
- Tile Diver
Re: Clutch renewal
Take advice from who ever is doing the job on your car as long as you trust them with regards to the Flywheel condition, I think a worn Flywheel has a bit play in it or signs of excessive wear, there are people on hear that can let you know the specifics. I didn't replace mine when the rest of the clutch was done as the mechanic said it was totally fine, I hope I don't turn out to regret that decision.Reffio wrote:What determines if the flywheel needs done and what's the possible impact if you don't do it when replacing the clutch?
Its the labour costs that kill you, so if the flywheel packs in 6 months down the line it's another gearbox out job, which at an Audi Stealer's will cost you around 8 hours labour which = Mega Bucks.
If the flywheel is seen to be in good condition then it's your call to get it replaced when the gearbox is out or not, I think a new Flywheel is around £700 / £800.
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Re: Clutch renewal
Ok thanks. Definitely seems to be a tricky one with a lot riding on what the mechanic thinks of the condition of the flywheel. Would be gutting not to do it only to be hit a couple of months down the line with another big labour bill to do the job!
Re: Clutch renewal
So I thought I would update you all
I had the full lot done, flywheel clutch, release bearing,new bolts and return pipe
Flywheel and clutch from loba and fitting by Autotechnica, job done was £1600
Clutch feels a little heavier but I guess it may give over time
Loba flywheel was massively lighter than the oem dual mass flywheel and the Andy at Autotechnica said it was a better assembly than the oem.
I am glad I did everything as although the clutch was not slipping it was nearly worn flat and only less than 1mm left on the clutch
Thanks to si from Loba for the free delivery
Well next is brake discs and pads
- Tile Diver
Re: Clutch renewal
Good result D8vil, that should be good for a long time!
There is a good thread on changing front discs and pads on here if you fancy doing it yourself!!
http://forum.rs246.com/viewtopic.php?t=96406
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
SS Suspension +
Sunroof
Stage 2 MRC Map
Cold Air Feed
Carbon Clean
Pre-Cats Gutted
447 PS
Re: Clutch renewal
My car is currently with an Audi dealer with the gearbox out awaiting their diagnosis of my sticking clutch pedal. It seems likely that they will agree with me that the car needs a new clutch. Bearing in mind that I have done 4,000 miles in less than 4 months since I bought the car from them what is the likely outcome? Would you expect them to recommend replacement of the flywheel as well?
Users browsing this forum: No registered users and 131 guests
