SD Card - MP3 Issues........ Help Please !
Re: SD Card - MP3 Issues........ Help Please !
Have a look on the divx website. I'm sure they do a free download converter. I've used it before and it is fine.
Current car: 2007 BMW 530d touring.
Previous car: 2005 S4 B7.
I have had this problem in the past, I solved it using a simple piece of software called wavepad. Just open the MP3 file, then save as MP3 file again and make sure fixed bit rate and the quality is set and click save, the songs then played fine for me
Hope that helps
Hope that helps
RS3 8P 2013 Phantom Black with Ally Pack and Black Optics Grille | LED Interior and number plate lights - GONE
RS4 B7 2006 Phantom Black with Titan alloys and mirrors - GONE
- 2nd Gear
ok thanks for that I'll give that a go tonight then.
| 2007 Daytona Avant | Buckets | 20" BBS CK's | H&R Coilovers | Valved Milltek res | hole in the fuel tank|
Sounds like it should be easily fixable - hope you get it sorted quickly
To be fair though, you did bring this problem on yourself - after all, if you'd left that non-res centre section in place, listening to the stereo wouldn't have been an option!
I had loads of issues with reading files initially and tried loads of programmes. The only fail safe way I found was to use iTunes convert to MP3 option and then copy the files directly onto my 2 x 4gb cards.
HD
HD
- 2nd Gear
Thanks for this tip. Downloaded it last night and its really easy to use, best feature by far is the batch loader so managed to convert 215 files in one hit. Took a while though !klauster wrote:I have had this problem in the past, I solved it using a simple piece of software called wavepad. Just open the MP3 file, then save as MP3 file again and make sure fixed bit rate and the quality is set and click save, the songs then played fine for me
Hope that helps
Glad u got sorted
Users browsing this forum: Majestic-12 [Bot] and 158 guests
