SD Card - MP3 Issues........ Help Please !
Batfinnk
Re: SD Card - MP3 Issues........ Help Please !
Post by Batfinnk » Sun Nov 11, 2012 10:31 pm
Have a look on the divx website. I'm sure they do a free download converter. I've used it before and it is fine.
Previous car: 2005 S4 B7.
klauster
Post by klauster » Mon Nov 12, 2012 6:04 pm
I have had this problem in the past, I solved it using a simple piece of software called wavepad. Just open the MP3 file, then save as MP3 file again and make sure fixed bit rate and the quality is set and click save, the songs then played fine for me
Hope that helps
slowmonkey
Post by slowmonkey » Mon Nov 12, 2012 6:07 pm
ok thanks for that I'll give that a go tonight then.
| 2007 Daytona Avant | Buckets | 20" BBS CK's | H&R Coilovers | Valved Milltek res | hole in the fuel tank|
pDkALO
Post by pDkALO » Mon Nov 12, 2012 6:52 pm
Sounds like it should be easily fixable - hope you get it sorted quickly
To be fair though, you did bring this problem on yourself - after all, if you'd left that non-res centre section in place, listening to the stereo wouldn't have been an option! :bigblink:
Current: Macan Turbo, Boxster 987 S
Gone: RS6 C6 Avant, RS4 B7 Avant, Tamora Speed Six
bravoit
Post by bravoit » Mon Nov 12, 2012 11:58 pm
I had loads of issues with reading files initially and tried loads of programmes. The only fail safe way I found was to use iTunes convert to MP3 option and then copy the files directly onto my 2 x 4gb cards.
HD
slowmonkey
Post by slowmonkey » Tue Nov 13, 2012 1:37 pm
klauster wrote:I have had this problem in the past, I solved it using a simple piece of software called wavepad. Just open the MP3 file, then save as MP3 file again and make sure fixed bit rate and the quality is set and click save, the songs then played fine for me
Hope that helps
Thanks for this tip. Downloaded it last night and its really easy to use, best feature by far is the batch loader so managed to convert 215 files in one hit. Took a while though !
klauster
Post by klauster » Tue Nov 13, 2012 10:45 pm
Glad u got sorted :) :beerchug:
Users browsing this forum: No registered users and 2196 guests
