RS4 B7 stock resonator delete
Re: RS4 B7 stock resonator delete
Post by MikeFish » Thu Aug 11, 2016 1:39 pm
jonson66 wrote:So what's the point in fitting an x pipe then? By the looks of it everyone is better off with a h?
My comments are the same for a h pipe. H and x are pretty much the same. The original exhausts are not connected to each other.
jonson66
Post by jonson66 » Thu Aug 11, 2016 1:45 pm
Ahh I'm with you so the original isn't an H pipe then? What's better then H or original?
Post by MikeFish » Thu Aug 11, 2016 2:00 pm
There is a theory that an X pipe or H pipe will increase scavenging or something like that with the exhuast gases and give you more power.
I doubt you'd notice the difference though. All the exhaust fabricators I spoke to said they wouldn't bother with it (but i know they are no experts on the subject and probably just wanted an easier exhaust to make). So theoretically a h or x pipe is better but debatable as to whether it is worth it.
I believe it also changes the sound slightly.
jonson66
Post by jonson66 » Thu Aug 11, 2016 2:06 pm
MikeFish wrote:There is a theory that an X pipe or H pipe will increase scavenging or something like that with the exhuast gases and give you more power.
What would you say gives the best sound? I've seen vids of yours with the tubi and it sounds epic but the jc weldfab sounds amazing. Not sure if they use a h or x pipe though
Post by MikeFish » Thu Aug 11, 2016 2:26 pm
My tubi had a h pipe. I cant say what the difference is like as I changed many things at the same time.
I know Ross did some testing with JCWF on his B8 whici ncluded swapping H for X to see the difference.
jonytek
Post by jonytek » Thu Aug 11, 2016 3:27 pm
For me and the reason I asked was more around not wanting to do a cheap job. I don't want to cut corners to save a few quid, it was not to try and squeeze out extra power.
BUILD THREAD
IG: @bad_rs_4
Post by MikeFish » Thu Aug 11, 2016 3:38 pm
jonytek wrote:For me and the reason I asked was more around not wanting to do a cheap job. I don't want to cut corners to save a few quid, it was not to try and squeeze out extra power.
In that case it is like I said, no x or h pipe will make it the same as it is now. If you are not after power then stick with straight through pipes, no need to complicate it for nothing.
Lukes3
Post by Lukes3 » Thu Aug 11, 2016 7:46 pm
I had a xpipe fitted the other day, sound wise didnt really notice a big change, posted pics of it in another thread.
viewtopic.php?f=35&t=121292#p806649
Seattle-squash
Post by Seattle-squash » Fri Aug 12, 2016 1:00 am
jonytek wrote:Definitely jumping on this. Are you guys letting your insurance know about this one?
Of course! That would be the only honest thing to do, together with letting them know that someone "stole" my front plate! :)
jonytek
Post by jonytek » Mon Aug 22, 2016 12:03 am
So I cut out the resonator over the weekend and to be honest I was expecting a little bit more. I was expecting more crackle and a deeper tone (valves disconnected).I'll be gutting the precats so we'll see if that makes a difference otherwise I will have to look into a JC Weldfab......
BUILD THREAD
IG: @bad_rs_4
jonson66
Post by jonson66 » Mon Aug 22, 2016 12:05 am
When I finally get one which I will, she will be getting a jc weldfab after weeks of searching for the best lol
Rw@@dy
Post by Rw@@dy » Mon Aug 22, 2016 5:53 am
You won't regret spending the money on a jc weld, it's awesome
FaisalJ
Post by FaisalJ » Mon Aug 22, 2016 8:38 am
Rw@@dy wrote:You won't regret spending the money on a jc weld, it's awesome
+1!
2007 RS4 B7 Avant
Rw@@dy
Post by Rw@@dy » Mon Aug 22, 2016 9:34 am
+1!
Saw your car in there on Friday while I was having mine fitted, looking good mate!
FaisalJ
Post by FaisalJ » Mon Aug 22, 2016 11:30 am
Rw@@dy wrote:
+1!
Thanks dude! Looking forward to getting it back tonight!
I was driving around the wifey's golf over the weekend, wishing I had my RS back already for the exhaust noise!
In case any of you guys haven't seen it:
https://www.youtube.com/watch?v=65SZXj4fTXA
Also, a couple of clips when the car had a modified OEM system, with precats deleted, an x-pipe, and valves stuck open:
https://www.youtube.com/watch?v=E-Bm-gmEP6E
Hard to pay attention to my car with David's R8 in this vid, but if you listen really really carefully....
https://www.youtube.com/watch?v=vxJwGPXlFE0
2007 RS4 B7 Avant
